HANDLEBAR CHANGE OUT
Old Mar 16, 2026 | 08:21 AM
kvnhpnr's Avatar
kvnhpnr
6th Gear
Default HANDLEBAR CHANGE OUT
My wife has a 2004 883XL and wants to change out the stock bars with mini apes but not sure which size to go with...she is 5'6" and she doesnt like the placement of the controls on the stock bars. The question is what is the max size I could go with to NOT have to redo cables or the brake line? I was looking at 7 or 8 inch with a max of 9 inch...will these sizes work with the stock cable/brake line?
Any help is greatly appreciated, trying to get everything she wants done while it is still cold in PA before it gets nice out.
Old Mar 16, 2026 | 08:50 AM
tmac00333's Avatar
tmac00333
10" for sure
12" probably
7 or 8" almost definitely
Old Mar 16, 2026 | 09:20 AM
kvnhpnr's Avatar
kvnhpnr
6th Gear
Thank you so much...that helps a a lot, now time to decide which height she wants to go with
Old Mar 16, 2026 | 02:58 PM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
The highest bars you can install without extending the wiring, cables and brake hose is 8".
If you want to go higher that 8", you have to take into consideration the expense of not only the mini-apes, but also the cost of a wiring extension and brake line kit, the $'s can mount up very quickly.
Old Mar 16, 2026 | 06:57 PM
DEATH_INC.'s Avatar
DEATH_INC.
I'm just over 5'6 and mine came with 10" T bars on it. They were pretty comfortable, until you got over 60mph. Combined with forward controls it was hard work to hang on at 70+. I don't know how you guys do the tall stuff.
I'd guess the t bars are about the same as 8-9" apes if you account for the stock 'risers'.
Old Mar 17, 2026 | 06:48 AM
Bubba Zanetti's Avatar
Bubba Zanetti
8 inches will work without any other mods on most bikes. I put a set of 10 inch mini apes on my Dyna and the only issue I had was the front brake line had to be bent a little. However the Dyna has very short risers on it, so thats another thing to consider.
travalab
Jun 5, 2013 04:11 PM
sickboy949
Aug 14, 2011 09:19 AM
aczaplicki
Jul 19, 2011 09:09 AM
txcreeper
Jul 3, 2009 11:05 PM
Otizzle
Mar 25, 2009 08:25 PM
