2000 sportster white smoke from cylinder
Old Mar 29, 2026 | 06:00 PM
Ebickhart15's Avatar
Ebickhart15
1st Gear
Default 2000 sportster white smoke from cylinder
I have a 2000 sportster 883 that I converted to a 1275 with a hammer performance big bore kit. After doing the conversion everything ran good until I messing with the exhaust studs and one broke off flush against the head. I then took the head off and brought it to a shop to get a new stud installed. Fast forward a few months I just put everything back together. I ended up replacing all the seals on the top end of the engine. After starting and letting it idle so I can listen for any unusual sounds I noticed white smoke coming from both cylinders. I doesn’t have any distinct smell to it. I’m relatively new to engine work and haven’t gotten enough knowledge to diag it myself, so any information on what could be going on is greatly appreciated. Thank you.
Old Mar 29, 2026 | 06:04 PM
John Harper's Avatar
John Harper
How much white smoke? Could be condensation depending on location, like your breath in cold weather. If it ran good before, it should run fine now. How many miles on your 1275 kit?
John
Old Mar 29, 2026 | 06:15 PM
Ebickhart15
1st Gear
[QUOTE=John Harper;22247684]How much white smoke? Could be condensation depending on location, like your breath in cold weather. If it ran good before, it should run fine now. How many miles on your 1275 kit?
I’m in South Jersey and we did just have a pretty cold and snowy winter. As for the smoke it wasn’t enough smoke to be super concerned. Like it wasn’t a big cloud that was pooling out it was more of like a constant light flow of smoke. The 1275 kit also has about 250-300 miles on it which is still within the 500 mile break in period for that kit.
Old Mar 29, 2026 | 07:45 PM
OCSpringer's Avatar
OCSpringer
I'd say that is normal for a new top end. There will be some light smoke initially as the rings seat and the assembly lube and what not burns off after putting everything together.
Old Mar 30, 2026 | 03:53 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Where exactly is the white smoke coming from though?
Old Mar 30, 2026 | 06:32 AM
Bubba Zanetti's Avatar
Bubba Zanetti
This is my initial thought too.
Old Mar 30, 2026 | 06:37 AM
Andy from Sandy
Depends where the smoke is coming from. Is it just oil on the actual cylinder burning off or from somewhere else? Does the instructions call for the whole thing to be given a good clean before firing up the engine for the first time?
Old Mar 30, 2026 | 01:21 PM
Ebickhart15
1st Gear
Ok thank you. I was planning on doing a few more heat cycles too.
Old Mar 30, 2026 | 01:22 PM
Ebickhart15
1st Gear
I couldn’t see where exactly it was coming from but I noticed most of the smoke coming from around the fins of the cylinder heads. Also when putting it back together I did give it a quick clean just to make sure there weren’t any big pieces of debris.
Old Mar 30, 2026 | 01:57 PM
OCSpringer's Avatar
OCSpringer
My guess it's just stuff burning off like greese and oil and what not that got on there during the building process. As long as it's running good I wouldn't sweat it.
khill8469
May 20, 2013 10:47 AM
madzac37
Jun 14, 2011 12:32 AM
BadBagger08
Dec 6, 2010 10:17 PM
Herr Monk
Jan 9, 2009 07:57 PM
fastolds
Motorcycles For Sale
Jan 6, 2008 09:09 PM
