Risers for Drag Bars?
Old Sep 10, 2007 | 12:19 PM
Dethlace's Avatar
Dethlace
Default Risers for Drag Bars?
Hey all,
I'm noticing some good back aches in my lower back after longer rides. I have an '03 Custom (drag bars) and was wondering if getting them pulled back a bit might help. I love the look of the bars, but wouldn't mind a hair more kicked back stance.
Anyone tried getting customrisers for this setup? Are there any folks would recommend?
Thanks!
Old Sep 10, 2007 | 02:04 PM
utz's Avatar
utz
Default RE: Risers for Drag Bars?
I am actually waiting to pick up my bikI had drag bars on it I know went with radious bars with a 8" rise on them with a pullback.It wasn't easy though because of the big speedo on sporties.So I replaced my stock speedo with a dakota digitial mini speedo which I mounted in between the riseres so I didn't take away from the look of my new radious bars will post a pic when I pick it up.
Old Sep 10, 2007 | 05:35 PM
TimC's Avatar
TimC
I inserted plastic riser bushings above and below the triple tree. Had to get longer bolts. But the setup did two things, brought the bars back and up just a little, but also dampened the the vibrations in the mirrors a little. The entire setup is about $20-$30
Old Sep 11, 2007 | 10:09 AM
Drodd8's Avatar
Drodd8
ORIGINAL: utz
Do you still have the stock bars and riser, and would you be interested in selling them?
Old Sep 11, 2007 | 11:07 AM
mr.hammond's Avatar
mr.hammond
could help,everybody's back is diffrent.
Old Sep 11, 2007 | 05:15 PM
AzDon's Avatar
AzDon
I've been hoping to find that someone is manufacturing a spacer plate that goes under the stock 1-piece riser on my '04 1200c. No luck so far though.... would also be cool if a set of dragbars was available with a shortriser hoop (like on top of dogbones)at the angle of the stock riser.
CGD
Nov 13, 2012 02:25 PM
Supernaut72
Apr 27, 2010 02:17 PM
SuburbanMom
Mar 4, 2010 08:12 AM
columbia whaler
Dec 2, 2008 03:33 PM
98fxd
Jun 19, 2005 02:53 AM
