Cold natured 883
Old Oct 24, 2007 | 10:25 AM
ron1019's Avatar
ron1019
Default Cold natured 883
I recently purchased a 2003 883R with a (1200)kit and is appears to be cold natured. After running a few minutes and I start to ride, I get a pop from the carbureator until it really warms up and then seens to go away. If I release the throttle sometines it will backfire or rumble through the pipes. Any suggestions??
Old Oct 24, 2007 | 10:51 AM
murphdog's Avatar
murphdog
Default RE: Cold natured 883
Usually replacing the stock 42 slow jet with a 45 and adjusting the idle mixture screw will fix that problem.
Old Oct 24, 2007 | 10:53 AM
pwnzilla's Avatar
pwnzilla
Does it have aftermarket pipes? That might explain the back firing, or maybe the carb needs adjusted again for the 1200 upgrade.
A 2003 Sportster will be a bit cold blooded, it's before they went to EFI by four years and one year before the rubber mounting changes.
Old Oct 24, 2007 | 11:37 AM
cHarley's Avatar
cHarley
If it only happens prior to the motor warming up, it isjust the nature of the beast (carb.). Don't change jets or adjust the carb based on what the bike does before it's up to temperature.
Old Oct 24, 2007 | 12:06 PM
lilredchic's Avatar
lilredchic
Mine does it also. I think its the nature of the beast like charley says.
Old Oct 24, 2007 | 02:19 PM
Dorkman's Avatar
Dorkman
Normal.
Old Oct 24, 2007 | 02:31 PM
Biker Trash's Avatar
Biker Trash
My '96 does the same thing. Nothing to worry about.
Old Oct 25, 2007 | 12:38 AM
JosephGarcia's Avatar
JosephGarcia
let the bike idle with choke for a minute from absolute cold, then release it slowly and let the bike idle until you can feel the heat coming off of the engine from a few inches. I do this with mine, after i can feel the heat i do a quick ride to the end of my block and back.
i just start the bike 5 mins earlier, and i dont get carb backfires or anything with this way.
Old Oct 25, 2007 | 02:12 AM
sgt joseph's Avatar
sgt joseph
ORIGINAL: JosephGarcia
Hey joseph, did you ever get to changing out your chain and sprocket yet?
Old Oct 25, 2007 | 02:26 AM
JosephGarcia
ORIGINAL: sgt joseph
my bike is going to an indy, there going to take care of everything. i took the forums advice and decided not to ride it in the condition it was in. although i had them inspect my bike at a dealer and the sprockets were good enough to just switch chains. they appeared in worse condition than they were.
