changing bars..
Old Jan 17, 2008 | 06:06 PM
motordrum's Avatar
motordrum
Default changing bars..
Just got a Nightster, it's my first Harley. Wanting to change to drag bars. I want to do it myself. Did it on my metric real easy. Is thisgoing to be just as easy???
Old Jan 17, 2008 | 06:08 PM
HDHornet's Avatar
HDHornet
Default RE: changing bars..
No
Old Jan 17, 2008 | 06:13 PM
motordrum's Avatar
motordrum
What will make it more difficult?
Old Jan 17, 2008 | 07:01 PM
GothMetalGuitarist's Avatar
GothMetalGuitarist
First off, welcome to the forums. If you are going from the std Nightster bars to drags, you will NOT have to change cables. It's a fairly easy job. Make sure your new bars are dimpled if you are going to run your cables externally. Running your wiring internally is a much more difficult job but ultimately looks cleaner. Should be as easy as pulling all your cables and controls off, remove your riser cap and bars, plop it all back together. Not tough at all.
Old Jan 17, 2008 | 07:55 PM
motordrum's Avatar
motordrum
So they have to be dimpled for external wiring?
Old Jan 18, 2008 | 02:17 AM
ColinB's Avatar
ColinB
ORIGINAL: motordrum
Not necessarily. You can file out the plastic on the switch housing to let thewires exit without pinching them if you have no dimples.
Old Jan 18, 2008 | 08:00 AM
motordrum's Avatar
motordrum
Ok, I see!
Old Jan 18, 2008 | 08:49 AM
carlo's Avatar
carlo
Get the HD service manual. Its worth it. Watch out for the front hand brake switch. You have to wedge a peace or card board in it as not to damage switch. Thats why the manual is good to have.
mwiles
General Topics/Tech Tips
Jun 18, 2018 11:34 AM
loosnut
Jul 1, 2011 09:40 PM
cozziem137
Sep 10, 2010 07:42 AM
The Reverend D
Mar 15, 2010 09:49 AM
Fivehorisun
Apr 16, 2009 11:01 AM
