Dead Batt.???????
Old Jan 14, 2006 | 02:18 PM
LUV2RIDE's Avatar
LUV2RIDE
Default Dead Batt.???????
my sporty makes a fst clicking sound when trying to start. it fails to start and the headlights dim. Is this because the battey is dead
Old Jan 14, 2006 | 02:41 PM
MuddyXL's Avatar
MuddyXL
Default RE: Dead Batt.???????
Maybe not "dead" but weak almost for certain. Try charging it up overnight with good slow rate charger (2 amps or less) for MC batteries like a Battery Tender. These modern batteries take longer to charge fully and too strong a charger will damage them.
Old Jan 14, 2006 | 02:44 PM
Slumpys1200c's Avatar
Slumpys1200c
Yeah, what MuddyXL said. Your battery sounds very, very weak! Good luck!
!!! RIDE SAFE !!!
Keith in Pa.
05 1200 custom "Lava"
Old Jan 14, 2006 | 04:14 PM
molsenice's Avatar
molsenice
was there once too many times wiht a previous bike - battery is low - youl be good to go with a full charge, make sure to disconect the battery first - don't need to remove it just disconect the positive and ground to a head bolt.
Old Jan 15, 2006 | 09:02 AM
Tim's Avatar
Tim
I would check the cable connections first. If not pull the battery and charge overnight and go to Auto Zone and have it tested. Tim
Old Jan 15, 2006 | 02:42 PM
LUV2RIDE's Avatar
LUV2RIDE
Thanks everyone....
Oscarthegreat
Jan 4, 2015 01:37 PM
BKSinAZ
Feb 14, 2013 12:39 PM
seven7
Aug 31, 2007 06:14 PM
Sally88
Jul 5, 2007 04:20 PM
claytonjwong
Feb 16, 2006 08:31 PM
