Since the last time you ran the bike with no engine problems... What changes, if any have your done? Pipes, aircleaner etc. Also look for loose plug wires at the ignition coil... they can become loose while cleaning and polishing the bike and cause mis-fire problems. Had that to happen to me once
That code was probably triggered from the carb back spitting freaking the MAP sensor out...Or the MAP is the problem creating a run-lean condition causing the back spit. You could replace the Manifold pressure sensor and then see what happens. Strange to have a MAP sensor on a carburator?
