Rake question
Old Feb 14, 2008 | 12:00 PM
oldmanjob's Avatar
oldmanjob
Default Rake question
Is the rake ofthe front forks the same for the regular size 883 sportster, and the hugger[sm=smiley25.gif]
Old Feb 14, 2008 | 12:03 PM
The Baron's Avatar
The Baron
Default RE: Rake question
Yes, all Sporty frames are the same.
I should say this, the neck rake on the frame is the same. The rake measured at the forks may be different as it will change with fork length and rear end height, and even tire height.
Lower rear = more rake when measured at the forks.
Longer forks = more rake when measured at the forks.
But the rake of the neck with the frame level will always be the same.
Old Feb 14, 2008 | 12:25 PM
OldFenderGuy's Avatar
OldFenderGuy
There is a slight difference in 'steering head rake' between the "C" models and the other Sportster models.
The 883C and 1200C have a steering head rake of 30.1 degrees, giving a total trail of 4.70".
The other models have a steering head rake of 29.6 degrees, and the total trail is between 4.60" and 4.70".
I added 14 degrees of total rake to my 1200C, so it is now running a total rake of 44.1 degrees, with a trail dimension of 4.6".
Old Feb 14, 2008 | 12:27 PM
Biker Trash's Avatar
Biker Trash
ORIGINAL: OldFenderGuy
Does this apply to 04+ or all late model Sportsters?
Old Feb 14, 2008 | 12:28 PM
The Baron's Avatar
The Baron
Whoops! Sorry for the misinfo. The Customs do have another 1/2 degree as confirmed from the Spec list on the HD site.
Old Feb 14, 2008 | 12:32 PM
OldFenderGuy
ORIGINAL: Biker Trash
Those figures apply to all the 2004+ models (with the modified frames)....
Don't have any figures handy, so I'm not sure offhand what the steering head (frame) rake is on the earlier models..
The rake for the older pre 2004 models is probably about the same, but I'm just not sure without checking...
Old Feb 14, 2008 | 12:39 PM
Biker Trash
No need to go searching OFG. I was just mildly curious. Thanks for the info OFG!
VoiceofReason44
Jul 13, 2017 06:59 AM
Shaved Ice
Jun 11, 2016 06:46 AM
WRONGWAY-XBONES
Jul 26, 2010 08:03 AM
XL OCD
Jul 6, 2007 09:46 AM
uglybiker
Jan 26, 2007 09:06 PM
