hyper charger question
Old Feb 15, 2008 | 11:33 AM
gmerr2's Avatar
gmerr2
Default hyper charger question
Here's a question for those of you with hyperchargers. When the butterflies are wide open...will it suck in water if it's raining? I've been thinking about getting one and some pipes and doing my own stage one, but I don't know that much about them....they look cool and everyone seems to say they work well...but I ride everyday, rain or shine or cold or whatever....it wouldn't work for me if I couldn't ride in the rain.
Rev. George.....Chattanooga, Tn
Old Feb 15, 2008 | 11:49 AM
Biker Trash's Avatar
Biker Trash
Default RE: hyper charger question
I would imagine they would suck in rain, bugs, bird ****, or whatefer will fly into it while riding. also those two little holes can't move all that much air (especially at high speeds when the wind resistance at 70-80 MPH is pushing those butterflies shut). If the butterflies were mechanical(like a top fueldragster's) instead of vacuum actuated (or if you rigged it so the butterflies stayed open all the time) it would more than likely work better.
Bottom line is they look cool but in all reality, a SE Heavy Breather or forcewinder (with water sock for inclimate weather) would be a better choice if you are lookin for true performance.
Old Feb 15, 2008 | 01:35 PM
Gigawitz's Avatar
Gigawitz
I have been caught in the rain a few times and had no problems with water. If a small amount of water did get sucked in, it would likely just de carbon the valves which is a good thing. You aren't going to suck in enough water to hydralock the engine so I wouldn't worry about it. The butterflys only open when vacuum is 0 under acceleration (idea is quick throttle response) they are closed at cruising speeds.
Old Feb 15, 2008 | 02:32 PM
hot77vette's Avatar
hot77vette
the only time you would have to worry about the water is if you drive into a lake.but on a serious side i rode in the rain with mine a lot had no problem !!!!!!!!!!
Old Feb 15, 2008 | 03:01 PM
gmerr2's Avatar
gmerr2
ah ha! I had thought they would be open most of the time....ok cool. I'm still weighing my options but I was kinda leaning toward the hypercharger.....it's a gadget...and I love gadgets. lol
Old Feb 15, 2008 | 03:41 PM
cHarley's Avatar
cHarley
There is a hole on the bottom/back end of the Hypercharger that will allow any significant amount of water to just run out of the unit. This same hole is what prevents the Hypercharger from actually functioning as a ram air intake. Excess intake air escapes through this hole rather than being "rammed" into the carb.[:'(]
Old Feb 15, 2008 | 07:10 PM
x2lee's Avatar
x2lee
Its also why the hypercharger is a form over function AC. It barely rates as an upgrade, a stock hamcan with a K&N filter moves 4 times as much air...
If Iran one I would rig a slider that would close that exit at will.
ORIGINAL: cHarley
bettingpython
Aug 11, 2017 07:41 PM
blackknight883
Jun 17, 2013 10:30 AM
STG246
14
Feb 3, 2013 01:51 PM
Superfly3176
Jun 7, 2012 04:27 PM
Ryding Rob
Jan 15, 2011 11:53 AM
