Winter mods completed
Old Mar 3, 2008 | 07:44 PM
SHOAT's Avatar
SHOAT
Default Winter mods completed
Yesterday I finished the last of themods I had planned for this winter.
Mods completed were:
-Replaced 2006 Dyna Low handlebars with 2007 XL1200 Low
handlebarsfor an additional 1" pullback.
- Installed Sundowner seat.
- Installed Brake light/Running light/Turn signal conversion kit.
- Replaced standard height HD windshield (plastic) with Memphis
Shades compact (15") windshield (plastic).
- Installed set of Easy Brackets.
- Installed set of Leather UP leather saddlebags. Look kinda
cheap (and they were) but they will do for now.
Previous mods included Relocated Turn signals and Cycle Shack Tapered Slip on mufflers.
Thoughts or suggestions?
Old Mar 3, 2008 | 11:35 PM
MayhemMike's Avatar
MayhemMike
Default RE: Winter mods completed
Productive winter
Old Mar 4, 2008 | 12:15 AM
hogsport's Avatar
hogsport
You have been busy - loks good. Two questions
Did you rigid nount the bags?
Do you need to exgtend wiring/cables for the 120 low bars? - I think that may be my next mod if I don't have to replace too much
Old Mar 4, 2008 | 12:36 AM
JosephGarcia's Avatar
JosephGarcia
it looks like alot of other sporties, but as long as its comfortable and does everything you need it to, ill praise that.
Old Mar 4, 2008 | 09:39 PM
cosmicHD's Avatar
cosmicHD
I like the bags. Those are a good size for the bike. What do they measure (L x W x D)?
Old Mar 4, 2008 | 10:11 PM
SHOAT's Avatar
SHOAT
hogsport -
The bags are mounted with Easy Brackets. The bags bolt to the brackets and the brackets arequick-disconnect. The brackets have a key-hole slots that mount onslotted spacers installed on the fender rail bolts.
All that was needed to mount the XL1200 Low bars was a longer brake line and to reroute the throttle cables outside the triple tree instead of through it.
cosmicHD -
The bags are 14" wide, 12" high and 5½" deep. If I had it to do again, I'd go with the Saddleman Drifter bags.
NickCats
Aug 13, 2020 08:15 AM
nightsterept
Nov 4, 2018 01:51 AM
Herbkell
2014-2024 Touring Models
May 22, 2014 12:36 AM
rojuwi
Nov 7, 2011 09:50 PM
BluesJopo
Jun 25, 2006 02:29 AM
