F-----G Little Light Bulbs
Old Mar 13, 2008 | 06:52 PM
vet767's Avatar
vet767
Default F-----G Little Light Bulbs
You know them little ones in the indicator panel? Is there some tool or trick to get the out. Left turn indicator does not work,bound to be a bulb, signal does and it is a pain to get the bulbs out. Finally got warm enough to ride when I was done with work. Only had and hour but it was great. Winter really sux.
Old Mar 13, 2008 | 07:29 PM
JosephGarcia's Avatar
JosephGarcia
Default RE: F-----G Little Light Bulbs
i know what you mean, i had my dash apart i was thinking or repainting it all to look new, i couldnt get those out and had to mask and spray around.
i think you have to disconnect wires somewhere and pull the whole assembly out from the front, i didnt want to deal with that though.
you should follow the wiring see where it ends up and if there is a harness or a quick connect and use two bare wires and a another compatible (power-wise) bulb and if it blinks u know to replace.
Old Mar 13, 2008 | 11:23 PM
oldgoat's Avatar
oldgoat
Try a straw. Press it over bulb & turn.
Old Mar 13, 2008 | 11:45 PM
6o66er's Avatar
6o66er
they just pop out....pull harder.
And if you're trying to disconnect the whole harness...it's the big 12(?) pin up front.
Old Mar 14, 2008 | 12:07 AM
SportyPig's Avatar
SportyPig
ORIGINAL: 6o66er
+1
Needle nose plyers, and just PULL.
Old Mar 14, 2008 | 01:39 AM
YodaddyKeith's Avatar
YodaddyKeith
Trick: Coat open jaw tips of needle nose with liquid tape...let dry....then reach in and grip n pull......then wire brush tape off pliers
Jim Valldeperas
2014-2024 Touring Models
Jan 25, 2017 09:17 AM
2fast4trouble
Nov 11, 2013 07:00 PM
Black Train
Feb 20, 2011 12:38 AM
rg567
Jun 30, 2010 06:38 AM
stoneman
Jun 24, 2007 04:32 PM
