Internal clutch adjustment
Old Mar 17, 2008 | 02:26 PM
jpowell490's Avatar
jpowell490
Default Internal clutch adjustment
Hey Guys,
My 08 883, the 1k service I did everything except this. I have the new manual but it is a bit confusing. Once I pop off the clutch cover, how do I adjust it right? The manual said something about turning until you felt tension, but it did not say which way. Treat me like a kid when explaining
Old Mar 17, 2008 | 02:43 PM
cHarley's Avatar
cHarley
Default RE: Internal clutch adjustment
You want to turn the adjusting screw counterclockwise until you feel tension, then back clockwise 1/4 turn.
Note: This is done after you have completely loosened the adjuster in the clutch cable.
Old Mar 17, 2008 | 02:45 PM
jpowell490's Avatar
jpowell490
so when I first start after loosening the clutch cable near the handlebars right?
Should I tighten the nut all the way clockwise then start back out?
Thanks charley
Old Mar 17, 2008 | 02:57 PM
cHarley's Avatar
cHarley
I don't know what nut you are talking about. You have to loosen the locking nut(s) on the cable adjuster in order to turn the adjuster and get plenty of slack in the clutch cable. The cable adjuster is located under a rubber boot where the clutch cable is clipped to the left front frame downtube. The clutch adjuster inside the derby cover is a screw not a nut.
Old Mar 17, 2008 | 06:17 PM
jpowell490's Avatar
jpowell490
ah ok,
Thanks cHarley
Comfortably Numb
May 3, 2021 12:45 AM
Gonzy
Jun 22, 2012 07:39 AM
big_e78
Aug 3, 2009 12:50 PM
geargrinder
Jul 10, 2009 09:41 AM
VARDR
Mar 26, 2009 08:37 PM
