Dead Battery
Old Mar 22, 2008 | 06:29 PM
Demonsmasher's Avatar
Demonsmasher
Default Dead Battery
Well I have a dead battery. Are those trickle chargers at walmart in thier motorcycle section good?
Old Mar 22, 2008 | 06:34 PM
sumdumtech's Avatar
sumdumtech
Default RE: Dead Battery
Trickle chargers are good for maintaining. If your battery is dead your gonna need a reg charger to bring it up to start it.
[IMG]local://upfiles/55106/1C7E8A064A0F4F8DAE672BAD0C1284AE.jpg[/IMG]
Old Mar 22, 2008 | 06:40 PM
Demonsmasher
Any sertin trype of regular charge to look for? I have a booster here for a car. Figured that would be to much for it. I really don't know what to look for. Haven't started it in a week so it's just now dead. What do I need to look for? Would a charger for a lawn mower work? Also would I need to take the battery out to charge it or could I do it on the bike and for how long?
Old Mar 22, 2008 | 06:48 PM
cHarley's Avatar
cHarley
You DON'T want a trickle charger, it will cook the battery if left on to long. You want to get a Float Charger (Battery Tender), they can be left on endlessly without harming the battery. You can find them in Walmat for around $20.
If the battery is stone dead, you will need a regular charger (2 - 10 amps) to bring it back up.
Old Mar 22, 2008 | 06:49 PM
Mandog's Avatar
Mandog
Battery Tender Junior
Product may vary from photo Lightweight, compact and fully automatic 2-stage lead-acid battery charger is ideal for hard-to-reach spots. A trickle charger assures batteries are maintained after charging and are always ready to go. The 12-volt model charges to 14.4 VDC, monitors the battery at 13.2 volts, and resumes full charging if the battery drops below 12.6 VDC. The 6-volt models charges to 7.2 VDC, monitors at 6.6 volts, and resumes charging below 6.3 volts. Includes 2-color LED indicator, reverse polarity protection, and a 12-feet output cord with quick-connect harness.
Old Mar 22, 2008 | 07:01 PM
Demonsmasher
So how do I need to use the tender charger? DO I have to take the battery off the bike or can I leave it on the bike?
Old Mar 22, 2008 | 07:05 PM
Demonsmasher
ORIGINAL: Mandog
Is this a tender charger AND a regular charger?
Old Mar 22, 2008 | 07:10 PM
Mandog's Avatar
Mandog
BOTH
Old Mar 22, 2008 | 07:17 PM
KSCruiser's Avatar
KSCruiser
The tender has a wire harness you attach to the battery and it stays on the bike. The charging pack plugs into it. Similiar to the picture.
Old Mar 22, 2008 | 07:40 PM
hogsport's Avatar
hogsport
I have the walmart trickle charger/tender and it works fine. It will charge a very low battery, but at 1.5 AH it ouwld take 10 hrs or so. Good value for $19.
