Oil
Old Mar 28, 2008 | 06:08 AM
nolafishr's Avatar
nolafishr
Default Oil
Would it be OK to use 10w40 in the Engine Oil instead of 20w50? It is not as thick of an oil and Summer is coming with the Hot Weather and was wondering about this. Do you need an oil this thick in it with the Hot Weather? I understand to use 20w50 in the primary for the 01 model.
I know this has been brought up mant times but want to get it straight because Iwill begettingmy bike next week and want to change out the oils to be safe.
2001 Sportster 1200
Old Mar 28, 2008 | 06:13 AM
Korbenw7p3c's Avatar
Korbenw7p3c
Default RE: Oil
When it's below 38*, and if you ride in the cold weather seasons, you should run 10w40. You SHOULD run 20w50 in the summer as the bike is air cooled and needs the extra protection of the heaver oil in the heat.
Old Mar 28, 2008 | 07:03 AM
valveguide's Avatar
valveguide
Default RE: Oil
Oil has 2 numbers, 10w40 say.
10 means the oil will never get thicker than 10 weight at 0 degrees.
40 means the oil will never get thinner than 40 weight at 200 degrees.
I found this definition surfing somewhere once ...
I think from the temperatures that I ride in I could run straight 50+ probably.
Old Mar 28, 2008 | 07:07 AM
cHarley's Avatar
cHarley
Default RE: Oil
ORIGINAL: nolafishr
NO. You need heavier weight oil in the summer not lighter.
Old Mar 28, 2008 | 07:12 AM
xFreebirdx's Avatar
xFreebirdx
Default RE: Oil
Seeing that you live in New Orleans, you need the heavier oil.
Old Mar 28, 2008 | 07:31 AM
1200c's Avatar
1200c
Default RE: Oil
Like several people have already said: you need thicker oil in the summer.
Old Mar 28, 2008 | 04:31 PM
MacAttack's Avatar
MacAttack
Default RE: Oil
What cHarley said. Air-cooled engines have looser machining tolerances as well, since temperatures vary more than liquid-cooled engines, and metal expands with temperature. HDs have always run thick oil.
Old Mar 28, 2008 | 05:38 PM
nolafishr's Avatar
nolafishr
Default RE: Oil
Thanks for the Info Guys, I just wanted to ask about it because I have heard of some people using the 10w40, I will stay with 20w50.
Old Mar 28, 2008 | 05:47 PM
TestFlyer's Avatar
TestFlyer
Default RE: Oil
Consider synthetic, too - she'll run cooler.
cajun1957a
Oil Archive (no new posts)
Aug 24, 2018 06:12 AM
SH_01FXDWG
Jun 13, 2015 05:13 PM
Rockrat
18
May 28, 2014 03:54 PM
jimmydon
Aug 10, 2009 05:57 PM
dynarule
Jun 15, 2009 05:19 PM
