06 exhaust question...
Old Apr 2, 2008 | 11:33 PM
Wolf4dk's Avatar
Wolf4dk
Default 06 exhaust question...
Hey guys/gals,[/align]Newbie here. Please bare with me. First, I would like to say that I am very impressed with this forum. I bought my bike (2006 1200 custom) last year. I love it.[/align][/align]My question is this, do I "need" to rejet if I plan to stay with a stock intake, and put on slipons? I have talked to a lot of people and it goes both ways. Some said that if you don't change the intake, you should be ok. But some say that you changed it a little, you should have to checked out and rejeted. [/align][/align]I should also let you know that when I brought it in for it's 1000 mile checkup, I had a small issue with it backfiring (coughing) when I would take off from a stop. But not all the time of course. So they said that they changed the main jet to a 45 from a 42. If this is the case, I would almost think that if I just threw on slip ons, that I wouldn't have to have it checked out and I should be ok. If not, what else do I need to worry about?[/align][/align]I guess the main reason I haven't done a full stage 1 is because I just don't see a reason for this bike. It's peppy enough for me and I don'tthink it's really worth the extra money they want for just an aircleaner.I just want to change the sound a little and make it so I can at least hear the exhaust while I ride.[/align][/align]Thanks for taking the time to help me out. I hope to get into a bigger bike when finances are a little better.[/align]
[IMG]local://upfiles/57419/45DE1698C9C644B2814EEB734BDEA219.jpg[/IMG]
Old Apr 2, 2008 | 11:35 PM
whylee's Avatar
whylee
Default RE: 06 exhaust question...
I would have it tuned just so your bike is running at its best, it can only help it.
Old Apr 3, 2008 | 12:23 AM
Kanzig's Avatar
Kanzig
Just for a sake of reference I have a 2006 883 Custom and it has SE II slip-ons and I dont believe it ever had anything done to the jets. (I bought it used.) It seems to be running great. I'm probably running somewhat lean but I don't think I have had a backfire yet.
Kanzig
Old Apr 3, 2008 | 08:18 AM
Thumper26's Avatar
Thumper26
What you will get out of slip-ons are a better sound and possibly a reduction in back pressure. You will not have to rejet as you are not changing the air/fuel mixture with a less restricted air cleaner. Put your slip-ons on and enjoy the added rumble without any other mods being necessary.
I doubt you even needed the #45 jet. Most likely a simple and small opening of your idle mixture adjustment screw would have done the trick (NOT the idle adjustment screw, unless your idle was too low).
Old Apr 3, 2008 | 11:15 AM
SportyPig's Avatar
SportyPig
Just to add pipes, there is no need to make any adjustments to the carb. I installed my pipes first, thebike ran fine that way with stock air cleaner and no carb work. After about 5,000 miles I added the Screamin Eagle air cleaner, and did the carb re-jet and tuning.
Old Apr 3, 2008 | 12:00 PM
kawsakimx6's Avatar
kawsakimx6
carb adjustments are not needed if there was no intake change
Old Apr 3, 2008 | 04:00 PM
06winner's Avatar
06winner
3rd Gear
I have a 2006 sportster 883. I was wondering if i knock out the tabs in the existing mufflers, how does it sound? I was told that the bike will have a tin canning sound. Anyone do this to there bike? Or do i just put on some slip-on? I don't want to spend alot of money. I want the bike to sound alittle louder then it does. Thanks for your input.
Old Apr 3, 2008 | 04:12 PM
kawsakimx6's Avatar
kawsakimx6
before i did the stage one i knocked the tabs out myself. They sounded pretty good.....BUT I only punched a hole in them and did not knock them completely out. you may want to think about that
Old Apr 3, 2008 | 04:23 PM
Wolf4dk's Avatar
Wolf4dk
Thank you all for your imput. Looks like I just need to find a good set of slipons that I will like. [/align][/align]Thumper26,[/align]The bike was under warrenty yet and so HD did the work.They brought up all the same fixes as you have but they decided to do the jet size change. I guess I can't complain cause I didn't get charged for it. It did take care of the problem. [/align]
Old Apr 3, 2008 | 05:24 PM
06winner's Avatar
06winner
3rd Gear
What size hole did you do?
