low idle miss
Old Apr 7, 2008 | 12:36 AM
1allen's Avatar
1allen
Stage I
Default low idle miss
My 2006 sportster 1200C started sputtering andbackfiring at the end of last years riding season. I changed the plugs checked air cleaner but no change. Today I first disconnected the front plug wire while it was idling it died. Hooked it back up and restarted it then disconnected the back plug wire. It stayed running the same. this makes me guess something electrical possibly coil or what else could it be. The bike has about 16000 miles on it and the only thing after market is the vance and hinse slip ons at 10000 miles ran good afterwards. please help outof work can't take it in.
Old Apr 7, 2008 | 01:12 AM
thruster's Avatar
thruster
Default RE: low idle miss
start cheap.
First replace the plug if that dont work replace the lead (of test it with a multimeter)
if no good it could be the coil.
All else fails = STEALER
Old Apr 7, 2008 | 05:31 AM
cHarley's Avatar
cHarley
Since you said you changed the plugs, the next easiest thing to try, is to swap the plug wires. (that means at both ends). If the problem stays with the rear cylinder, the next shot would be to replace the coil.
Old Apr 7, 2008 | 07:24 AM
muns's Avatar
muns
Like cHarley said, check the plug wires. Also, since you have an 06 your coil has 3 input wires from the ICM. They are: Front Cylinder-Common-Rear Cylinder and all are low voltage. I would also check thoseinput connections on the coilas well as the ICM connector plug under the seat.
SEMJPM
thumbbuster
Nov 9, 2017 03:12 PM
Jonathan Tooher
General Topics/Tech Tips
Feb 29, 2016 09:17 AM
Coastiejosh
Jul 5, 2012 01:08 PM
ethrjock
Jun 14, 2007 10:35 PM
UNCLE SAMMY
Apr 22, 2007 02:00 AM
