spark knock issue
Old Apr 21, 2008 | 12:21 PM
kidcrappr's Avatar
kidcrappr
Default spark knock issue
I have a 1200evo motor with spark knock issues when it is fully warmed up. I use premium fuel,have tried several brand's, and the timing has been checked and is on the money. I also had the carb gone thru to make sure it was'nt a lean issue. I also had the intake gasket's and carb boot replaced and checked for leak's. ANYONE OUT THERE HAVE ANY FRESH IDEA'S? Please help if you can! Thank's guy's! Ride safe!!!
Old Apr 21, 2008 | 12:33 PM
cHarley's Avatar
cHarley
Default RE: spark knock issue
Under what conditions are you getting the spark knock (speed, gear, adding throttle)? While it's not right, some knock is not unusual in the 1200s at 50-55 mph in 5th gear and additional throttle is rolled on. In my case, I found the factory ignition timimg and advance curve in the ICM to be the problem. Basically, the factory ignition curve sucks.
You also could have a bad VOES sensor.
Since you don't list the year of your bike I can't be of more help.
Old Apr 21, 2008 | 12:45 PM
kidcrappr's Avatar
kidcrappr
Sorry, it's a 98 1200 and thank's for any and all help.
Old Apr 21, 2008 | 12:49 PM
kidcrappr's Avatar
kidcrappr
sorry, it's a 98 1200. it occur's when first powering up in 1sy, but sometime's it goe's all the way to 3rd gear. It usually happen's only for the first half second in each gear until the rpm's come up. thank's for any help.
Old Apr 21, 2008 | 01:17 PM
cHarley's Avatar
cHarley
At what speeds are you shifting into 2nd and 3rd?
John O'Hara
EVO
17
Feb 22, 2017 08:44 PM
Custom Zach
Jun 14, 2013 03:13 PM
HighwayBobbery
Jun 3, 2011 12:53 AM
jayride
Engine Mechanical Topics
Mar 28, 2010 09:59 PM
dirtpirk
Exhaust System Topics
Feb 7, 2006 05:18 PM
