Brainbuster.....
Old May 5, 2008 | 07:54 PM
6o66er's Avatar
6o66er
Default Brainbuster.....
Ok...so I've just installed a new clutch, new ball and ramp, and made sure everything was nice n tightened up. Now I'm having issues with mis-adjustment in my clutch.
The primary chain is exactly to spec, the cable is being adjusted properly for clearance, and everything is installed correctly. When I start the bike and hit 1st, it pulls forward so bad now that it stalls itself out unless I'm moving.
My thoughts on what it possibly could be:
Adjusting screw for the ball and ramp
The pressure spring that fits over it
And the threaded key that holds the ball and ramp in place
Or the slack adjuster for the primary chain
Everything else is pretty much brand new. There were no signs of sheared gears/sprockets or damage to any major components.
Your thoughts? I may just replace the above parts anyways, but I could always use a good brainstorming session for other possibilities.
Old May 5, 2008 | 07:57 PM
cHarley's Avatar
cHarley
Default RE: Brainbuster.....
You didn't drop a ball did you? Just a thought.
Old May 5, 2008 | 08:03 PM
6o66er's Avatar
6o66er
Good point...it was moving ok when I was trying to readjust it real quick before work. I'll have to check that out. Aside from that I really can't think of anything else it could really be...the cable is brand new and working about as good as a cable can, lol.
Old May 5, 2008 | 08:22 PM
6o66er's Avatar
6o66er
Anyone else?
Bueller?
Bueller?
Bueller?
Bueller?
Bueller?
Old May 5, 2008 | 08:53 PM
trailey97's Avatar
trailey97
thats a bummer for sure
still a bad *** bike though
Old May 5, 2008 | 08:55 PM
6o66er's Avatar
6o66er
Eh, **** happens...i'll be back on the road tomorrow. Always am. It's just gonna be a PITA to track down the parts, I think.
Old May 5, 2008 | 09:46 PM
Gnight's Avatar
Gnight
Sorry I can't help but good luck on that man, I know that's your daily rider so..hope you get that **** fixed asap.
Old May 5, 2008 | 09:50 PM
MyBluOx's Avatar
MyBluOx
Did you make your adjustment with the bike at temperature.?
Old May 5, 2008 | 10:10 PM
6o66er's Avatar
6o66er
Shouldn't really matter...but no.
Old May 6, 2008 | 02:42 AM
LoneRyder's Avatar
LoneRyder
Hey bud, any chance that you tightened the pressure plate nut (#10 in the pic) down? Because I believe the manual says that tighten until finger tight then back a 1/4 turn. It's supposed to have slack in it for the clutch to perform right. Just throwing the thought out there.
[IMG]local://upfiles/34717/CEC3DE4FA6E5491E8EE4A16DA8057D77.jpg[/IMG]
