04' or later 1200c riser replacement.
Old May 5, 2008 | 08:14 PM
factoryhdtech's Avatar
factoryhdtech
Default 04' or later 1200c riser replacement.
Has anyone on here ever replaced the riser on their 04 or later 1200 (or883) custom, and managed to retain the speedo? I'd like to install a set of apes, but I think they would look ridiculous with the OEM riser. I also want to be able to continue to pull DTC's from the speedo, thats why I don't want to change it.
Any thoughts from you clever folks out there would be appreciated.
CS
Old May 5, 2008 | 08:36 PM
georgiabiker's Avatar
georgiabiker
Default RE: 04' or later 1200c riser replacement.
I have the original with apes and really don't like it. I got creative and with a little cutting could flip the speedo and idiot lights upside down to install a tank lift. I never could find a set of straight risers that would work with the upside down speedo.
Good luck, let me know if you find anything that works.
Old May 5, 2008 | 08:54 PM
Terp84Alum's Avatar
Terp84Alum
I don't get it. The riser on the 04 and newer Customs is so much nicer than mine. Why are you guys looking to take them off?
Old May 5, 2008 | 09:02 PM
factoryhdtech
ORIGINAL: Terp84Alum
Don't get me wrong I like the riser with the stock bars or drag bars, it's just with apes, I think it looks a bit busy.
Old May 5, 2008 | 09:08 PM
factoryhdtech
ORIGINAL: georgiabiker
Hey Georgia, I hope i didn't offend you about my opinion on the apes. I like what you have done with the struts on you scooter, it looks tuff.
Anyway you see what I mean abouth the riser? Apes look great on that bike, but it's just too much with the stock setup. I'm going to try a few things, and i'll keep you informed.
Peace
cs
Old May 5, 2008 | 09:35 PM
georgiabiker
I love the stock risers, but the curve does not look the best with the apes. I would rather go with straight risers. I was wondering if I could flip the stock speedo case 180 degrees and put a new set of risers on reversed and make them work. Also no sure how the straight risers would work with the stock speedo. If you take the stock speedo riser off, there are 2 small screws. Remove them and the speedo will come out of the case. The trip reset rubber button screws off and you can remove it.
Old May 6, 2008 | 07:11 AM
freekinfreak's Avatar
freekinfreak
I swapped mine for a 98 Custom riser. Chopped it down about 1.5", just under the Harley stamp. Looks much better now, and still hides all the wires.
Old May 6, 2008 | 08:50 PM
sportyc05's Avatar
sportyc05
I just used an older xl speedo mount with 4" risers, nice clean look, IMO.
Old May 7, 2008 | 06:41 AM
capttawes's Avatar
capttawes
I run the same setup as sporty05. Perfect and cheap alternative when replacing stock riser/speedo combo.
Old May 7, 2008 | 07:33 AM
nevets61's Avatar
nevets61
Sporty05 or Capttawes,
Do either of you have the part number of the bracket you are using. That would be very helpful to those of us with customs that want to change the riser and are baffled as to how to best keep the speedo on the riser... I'd really appreciate the part number or any info that might help me/us locate the bracket.
Thanks...
