Enrichener Adjustment Needed?
Old May 13, 2008 | 02:37 AM
BluePotato's Avatar
BluePotato
Default Enrichener Adjustment Needed?
Typically, I've needed to keep the enrichener out (or partially out) for my first 1/2 mile or so before I push it all the way in. Lately, the bike has been difficult to start (even with the enrichener fully out) and when it runs, I can't keep the enrichener all the way in or it will nearly die when I open the throttle from idle. So, I've had to keep the enrichener partially out even if I've been riding for 20 miles.
Has anybody experienced this problem before? What is the source of the problem and what is the fix? Thanks.
Old May 13, 2008 | 02:43 AM
Mississippi Bagger's Avatar
Mississippi Bagger
Default RE: Enrichener Adjustment Needed?
Have you checked for an intake manifold leak?
Old May 13, 2008 | 07:42 AM
Zimbob's Avatar
Zimbob
Either an intake leak or your plugs are FUBAR from fouling. Try upping the rpms just before you idle it to park, the rpm's should return to where you had them. Have you pulled the plugs and had a look at them to see if they need to be replaced?
67Shuv
Jun 22, 2019 11:16 AM
DDH
The Dyno Room
May 9, 2016 06:54 PM
RollingBurn
Engine Mechanical Topics
Apr 22, 2015 09:40 AM
jett78
Exhaust System Topics
Mar 9, 2009 07:51 AM
guitarenigma
Aug 20, 2006 01:52 PM
