upper fork tubes
Old May 14, 2008 | 09:26 PM
Mark g's Avatar
Mark g
Default upper fork tubes
Has anyone on here changed them out?
I have a "N" with the shorter tubes and ordered the stock tubes from a "C" model 2" longer. Planning on swaping them. How long of a job? Any helpful tips?
Should look pretty Cool with the longer tubes
Old May 15, 2008 | 05:50 AM
Nonstop's Avatar
Nonstop
Default RE: upper fork tubes
Are you looking for more travel? I often find i bottom mine out on some of the roads round here. Interested in seeing what you find out.
Old May 15, 2008 | 07:31 AM
capttawes's Avatar
capttawes
With a service manual and the right tools its not difficult. But its a serious pain in the butt getting fork seals in and out which is necessary to get the tubes out of the stock legs and the dampers/rebound springs out.
Old May 15, 2008 | 08:17 AM
Mark g's Avatar
Mark g
ORIGINAL: Nonstop
It won't have any more travel, unless changing the lowers. I'm just changing the stance of the bike.
If you are bottoming out alot, check into some heavier springs. They are real easy to change out to.
Old May 15, 2008 | 09:14 AM
BLKXL12C's Avatar
BLKXL12C
If you would have done this in the winter I would have swithed tubes with you. I'm wanting to lower mine and will be putting in a lowering kit soon so i'll have my forks apart but going to do it all at once so I don't want to miss any riding time.
whylee
Apr 29, 2019 04:19 AM
Flintshooter54
Nov 30, 2011 09:19 AM
Swilkins
Mar 29, 2011 10:16 AM
'05Train
Aug 9, 2010 11:31 PM
Bendleface
Apr 9, 2009 08:20 AM
