I'm getting a lot of buffering on the top of my head with the windshield installed. It's a smaller shield that attaches to the bars. Should the shield be closer to me? I have it raised as high as it goes. Any help would be appreciated.
I have an 06 1200 Custom with the HD quick detach windshield and I have been experiencing the same thing. The top of the windshield is at about nose level when sitting upright and my head is vibrating to the point of not being able to see clearly at highway speeds. I have found that the problem for me is the wind coming from underneath the windshield and then up my legs and chest and hitting my helmet. The vibration is amplified if you don't have your helmet really secure. There is another post with a guy who installed a set of Memphis Shades lowers to deflect most of that wind away. I ordered these a few days ago and will be getting them installed and test them out.
When you are riding, try putting your left arm across your chest and see if that helps the buffering....If it does, its the wind coming from underneath, not over the top of the windshield.
I had the same prob. w/ my HD QD shield. I took the visor off my helmet and it went away.
+1!!I run NO windshield and youll be amazed what taking off that crappy little visor does to smooth out your ride. ...Assuming you run a helmet with a visor...
I removed the visor and took the highway to work and it did cut down on quite a bit of the buffering. I finally received my Memphis lowers and hope to get them installed in the next day or so. I am leaving on a ride to Minneapolis next Friday so I need to get these installed ASAP.
Josh
