help with finding oil drain plug!!!
Old May 30, 2008 | 03:05 PM
chilango13's Avatar
chilango13
Default help with finding oil drain plug!!!
I know this might sound stupid, but I can't seem to find the oil drain plug to change the oil on my friend's sportster. I also need to know where the primary drain plug is located. Sorry for the dumb *** questions, but this is the first time I mess with a sportster. Thanks Roman. Any pictures would help!!!!
Old May 30, 2008 | 03:18 PM
ride2tires's Avatar
ride2tires
Default RE: help with finding oil drain plug!!!
I know my 02 has a hose clamped to a bung on the right hand side of the bike just in front of the rear tire.
Hope this helps.
Old May 30, 2008 | 03:23 PM
JosephGarcia's Avatar
JosephGarcia
i have a 1988 and the oil drain is like this
it is a 1/2 inch tube coming from the bottom of the oil tank to the left side of the bike. underneat the battery cover tray there is a small nipple and the hose is connected to, there is a clamp here to keep it tight. to change the oil i loosen the clamp and position the hose over a bucket, all the oil in the tank flows out.
check for the hose underneat the battery.
might have changed it in new models, i dont know
as for primary drain plug...... beats me.. when somebody else posts here about where that is, it will help us both!
my primary leaks, so im constantly refreshing it with new oil... which means im not too worried about the stuff in there getting burned or worn
Old May 30, 2008 | 03:29 PM
HOTLAP's Avatar
HOTLAP
My 07 has a hose hanging down under the transmission area, it has a gear clamp and a black plastic plug (motor oil), the primary has a drain plug in the bottom of the housing directly below the derby cover.
Old May 30, 2008 | 04:23 PM
Dorkman's Avatar
Dorkman
2004 has a hose clamped to the bottom frame below the derby cover, left side. Pull the clamp off the frame to release the hose, unscrew the band, take out the plug to drain the engine oil. The primary drain plug is on the underside of the primary case, left side, below the derby cover. It is not the one with the lock nut ahead of it.
Old May 30, 2008 | 04:25 PM
128auto's Avatar
128auto
Dorkman
Riding a Fatboy now?
Old May 30, 2008 | 04:33 PM
Dorkman's Avatar
Dorkman
ORIGINAL: 128auto
Dorkman
Yep.I was suffering from SIS (Sportster Inadequacy Syndrome)
Old May 30, 2008 | 05:31 PM
cHarley's Avatar
cHarley
And the Year of your friend's Sporty is ?????????
jbob
Oil Archive (no new posts)
20
Aug 17, 2015 08:02 PM
HDGent
Jun 30, 2011 08:30 PM
mtonyl
Jul 27, 2009 09:10 PM
rivercityslim
EVO
Aug 30, 2007 01:05 AM
Blue eyes 56
Exhaust System Topics
Mar 7, 2007 02:33 PM
