Dim Headlight
Old Jun 5, 2008 | 04:45 AM
jerryh57's Avatar
jerryh57
Default Dim Headlight
Might sound like a silly question, but the headlight on my 07 883 just seemed to get really dim over a space of a few days. It's noticeably dimmer when it's very dark and makes it hard to see. Bike only has 1900 miles. Have cleaned the outside, and am considering pulling it and cleaning the inside. Not really any discoloration that I can see. Just wondering if this has happened to anyone else and what caused it. Any and all help greatly appriciated.
Old Jun 5, 2008 | 04:54 AM
dbleagle's Avatar
dbleagle
Default RE: Dim Headlight
I'd say more than likely its a bad ground... seen it many times....
&nbsp\\;
Charlie D.
Old Jun 5, 2008 | 05:07 AM
Bossman1's Avatar
Bossman1
&nbsp\\;Ditto bad ground how is other beam????
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&n bsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbs p\\; Bossman
Old Jun 5, 2008 | 07:27 AM
capttawes's Avatar
capttawes
Bad ground as mentrioned. Lift the tank and pull the connector plug and spray sockets with some WD40&nbsp\\;as its likely got some corrosion weakening the ground contact.
Old Jun 5, 2008 | 07:34 AM
6o66er's Avatar
6o66er
It could also be burning out the socket....pop the lens and check it out.&nbsp\\; I had this problem...cheap *** bulb ate through the connector.&nbsp\\; Bought a replacement and rand heavier gauge wire with a 20$ hyperwhite bulb...still have no problems to this day.
Old Jun 5, 2008 | 08:08 AM
jerryh57's Avatar
jerryh57
Thanks&nbsp\\; guys, I will check the ground and go from there. The hi beam is dim as well.
Old Jun 5, 2008 | 08:35 AM
drum412's Avatar
drum412
Yep, most likely a bad connection, may wanna try a new bulb for the heck of it too. &nbsp\\; When checking the connectors, slop some dielectric grease on them before reconnecting them.&nbsp\\; Otherwise since it's a newer bike, you could call the dealer and see if it's a warranty issue, then they can mess around with it.......downside is then you may be without a bike for a few days.&nbsp\\; If it's an issue with the wiring it'll be covered under warranty, but if it's the bulb then it's considered maintenence at your cost. &nbsp\\;&nbsp\\; Do not use WD40 on electrical connectors, for one it's conductive, but worse, it attracts dust and dirt buildup.&nbsp\\; If connectors are dirty use electrical contact cleaner, and then slop dielectric grease on them.&nbsp\\;
Old Jun 6, 2008 | 06:42 PM
james_f's Avatar
james_f
I had a problem with a dim light but it turned out the light was not properly adjusted new from the dealer.
Old Jun 6, 2008 | 06:51 PM
SpursDarkrider's Avatar
SpursDarkrider
do they sell electrical contact cleaner at auto parts stores?
&nbsp\\;
Old Jun 6, 2008 | 09:07 PM
CapnAdventure's Avatar
CapnAdventure
Yes.
[IMG]local://upfiles/48168/45EBAD4D94B4442F9D8786D59D2DA12F.jpg[/IMG]
kjkustoms
Jul 11, 2008 08:55 PM
EdwardK
Jun 29, 2008 09:37 AM
ScooterJammer
Jun 23, 2008 12:06 PM
anmith
Jun 20, 2008 06:58 AM
major_bigdino
EVO
Jun 12, 2008 09:40 AM
