Ok I hope this is an easy one - just lookin not to break anything. For those of you who have swiched out the choke / Erinchner, whatever you want to call it ****, to the chrome one, How the frig does it come off?
Is it threaded? or is it just a press fit? - I would like to take it off so I can cast one of my own, I'm thinkin of doin an Eagle or one of about a hundered Ideas I have
brohrs - thanks for the reply, I too am betting that it is pressed on since I can find no pin or clip holding it on. However, I really don't want to snap off the adjustment lock screws behind the ****, as they are plastic[:@] and I have given it a gootinstrong pull and nothing seamed to budge. well if I break the thing, I'm sure I'll come up with a fix - the frigin thing has to come off some how, might try a heat gun to soften it up a bit, unless anyone can clue me in.
There aren't any destructions with the new one? Only thing the catalog says is that it installs in minutes. Couldn't find anything in the repair manual.
It's a compressed fit - won't come off unless it breaks (or you cut it off). You can buy different covers for the existing ****, or replace the **** (replacements typically have a set screw). Some have built custom *****, and drilled/tapped their own set screw. Also, replacing the stocker (it's actually an assembly of **** and cable) is only about $15 if you screw up (one of the cheaper mistakes you can make - lol!).
Cool just what I suspected - It's a Blue Tiped Wrench Special (Burn it the frick off with the acytalyine tourch)[sm=bounceybounce.gif][sm=badbadbad.gif][sm=bounceybounce.gif] fun timefor the pyro
This I will need to capture on vidieo just to settle the (choke / enrichner) debate[8D]
Thanks all - not trashin anythin till I "cast up" somethin acceptable - god I am tooooooo frigin cheap - I really should actually buy somethin, but I'm also bored and 3-4 days of dickin round shur beats complainin about the snow
