i need some help
Old Jun 12, 2008 | 05:44 PM
01sportynh's Avatar
01sportynh
2nd Gear
Default i need some help
fuel isnt getting to the cylinders. spark plugs are dry. i check the res. valve, looks good, replaced the filter as well. wasted out my tank which emptied a ton of junk. still not getting fuel. any suggestions or trouble shooting methods? any help would be great. thanks guys.
Old Jun 12, 2008 | 05:53 PM
JosephGarcia's Avatar
JosephGarcia
Default RE: i need some help
take off your carb and soak it in carb cleaner overnight, then spray out evrey orifice with the aerosol cleaner &nbsp\\; then replace the air and fuel filters
Old Jun 12, 2008 | 05:54 PM
JosephGarcia
also when you reassemble your carb make sure to set the float height and diaphragm correctly. and run a tank with the additive SeaFoam every other tankful.&nbsp\\;
Old Jun 12, 2008 | 05:58 PM
JosephGarcia
it should go without saying to replace your fuel and vaccuum hoses as well.
splitting my post into 3 to prevent posting errors from the forum....
Old Jun 12, 2008 | 07:10 PM
higg47's Avatar
higg47
Maybe a little more info might help us help you...kapeesh?
Old Jun 12, 2008 | 08:31 PM
01sportynh's Avatar
01sportynh
2nd Gear
well i went to start my bike the other day..it started right up like usual and idled with the choke on for about 8 mins maybe. I was warming the bike up for a ride, but it ended up stalling out. I went out to restart it and couldnt, had power and it would turn over, but not start. when i spray starter fluid into the carb it starts but dies out when the fluids burnt off. knowing i had a fuel problem i took the take off and disassembled the reserve valve. all the internals looked good so didnt touch them. but did replace the filter. i also flushed out the tank, look layer of rubbery stuff inside the tank came loose..a decent amount of it came out when i flushed the tank. I flushed it a couple times until there was little to none coming out. I then put everything back together and gave it a try. No go. I am planning to take a closer look at the fuel lines..maybe there is a possible pinch in the lines I dk..just looking or ideas or troubleshooting. Any help is appreciated.
Thanks guys.
Purple89
Jun 27, 2016 05:56 AM
CaptainCalf
Nov 17, 2012 11:12 AM
Deuce55
Exhaust System Topics
May 17, 2010 09:17 PM
Deuce55
May 4, 2010 04:30 PM
chevys
Jul 5, 2007 04:54 PM
