Free performance mod
Old Jun 15, 2008 | 03:12 PM
ekaphoto's Avatar
ekaphoto
Default Free performance mod
I raised my forks 1/4 in. on my 2007 XL1200R. It takes the corners much better and turns easier. I ran it up to 90 mph and it was stable at high speed as well. If you have a sportster and want to make it a little better in the corners, you may want to give it a try.[/align]
&nbsp\\;\\\\\\;[/align]
Old Jun 17, 2008 | 06:40 PM
titus3:5's Avatar
titus3:5
Default RE: Free performance mod
How did you raise it???&nbsp\\; Did you add extra oil, change the spring??? Just what did you do to raise it 1/4 inch
Old Jun 17, 2008 | 07:05 PM
cHarley's Avatar
cHarley
ORIGINAL: titus3:5
How did you raise it???&nbsp\\;\\\\\\; Did you add extra oil, change the spring??? Just what did you do to raise it 1/4 inch
For a 1/4" I assume he just slipped the forks down in the triple trees.&nbsp\\; I wouldn't expect any noticeable change in handling with that small of a change.
Old Jun 19, 2008 | 09:13 AM
ekaphoto's Avatar
ekaphoto
ORIGINAL: cHarley
ORIGINAL: titus3:5
How did you raise it???&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; Did you add extra oil, change the spring??? Just what did you do to raise it 1/4 inch
For a 1/4" I assume he just slipped the forks down in the triple trees.&nbsp\\;\\\\\\; I wouldn't expect any noticeable change in handling with that small of a change.
&nbsp\\;
Yes I lowered the front 1/4 inch. It does make a diffrance, just a little bit can make a diffrance.
Old Jun 20, 2008 | 06:53 AM
nevets61's Avatar
nevets61
I raised mine an inch... The custom front seemed low to me so I took off the caps and placed a 1" x 1 1/8" spacer on top of the spring and put the caps back...&nbsp\\; Mind you that you will have to work a little harder to get the cap back on but it sure made my bike stance better... And yes, it still handles well thru all speeds...
Old Jun 20, 2008 | 07:34 AM
capttawes's Avatar
capttawes
I've played with sliding my fork tubes up/down a lot over a couple yrs. and 1/4" actually make s a huge differnce. Of course since I have apes I think you can feel a more immeidate change in steering vs. low bars.
Old Jun 20, 2008 | 09:03 AM
2kanzam's Avatar
2kanzam
ORIGINAL: ekaphoto
ORIGINAL: cHarley
ORIGINAL: titus3:5
How did you raise it???&nbsp\\;\\\\\\;\\\\\\\\\\\\\\;\\\\\\\\\\\\\\\ \\\\\\\\\\\\\\\; Did you add extra oil, change the spring??? Just what did you do to raise it 1/4 inch
For a 1/4" I assume he just slipped the forks down in the triple trees.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; I wouldn't expect any noticeable change in handling with that small of a change.
&nbsp\\;\\\\\\;
&nbsp\\;
OK, I'm confused, First you said raised, then you said lowered.&nbsp\\; Is the front of the frame closer to the ground or farther away now?
Old Jun 20, 2008 | 09:06 AM
ekaphoto's Avatar
ekaphoto
The frame is closer to the ground.
Old Jun 20, 2008 | 09:10 AM
Sick1200's Avatar
Sick1200
2kan- By raising the forks, you lower the frame. And yes, a 1/4" will make a huge difference! When I was at MMI they stressed to the mm. on the forks.
OldFenderGuy
Jul 11, 2008 11:13 PM
chaswood
Jul 6, 2008 08:20 PM
