'06 Sporster starting problems
Old Jun 15, 2008 | 09:31 PM
loner19532004's Avatar
loner19532004
Stage III
Default '06 Sporster starting problems
I have a '06 Sporster, I tried to start it this morning. It turned over and started but died. On next attempt to start the lights went dead and even with the key out of the ignition the speed&nbsp\\;odmetor gauge jumps around. After sitting for about 30 minutes when the ignition is turned on the lights come on but as soon as you hit the start buttom the lights go out and there's nothing. Any sugestions.
Old Jun 16, 2008 | 07:39 AM
3/4 life crisis's Avatar
3/4 life crisis
Default RE: '06 Sporster starting problems
Check battery cables, esp. ground on both ends.&nbsp\\; I have a '07 that did that once, turns out to be neg. battery cable is loose @ terminal.
Old Jun 17, 2008 | 03:39 AM
trmac's Avatar
trmac
Big Kahuna HDF Member
Had the same thing on my 05.&nbsp\\; Roll the bike back just a bit and try starting again.&nbsp\\; Mine would give a clunk from the starter then all electrics died.&nbsp\\; Only took between 5 and 10 minutes before electronics came back after failed attempt.&nbsp\\; I think its caused by the idler gear or one of the others in there not being properly lined up.&nbsp\\; Only had it happen once but took about 10 tries before it started and just before the last try I rolled the bike back a little.&nbsp\\; Only needs an inch or so.
Old Jun 17, 2008 | 08:22 AM
Nightbreed's Avatar
Nightbreed
Stage III
I had excactly the same thing on sunday. turns out the positive cable on the battery was loose
Old Jun 17, 2008 | 08:50 AM
Zimbob's Avatar
Zimbob
As stated above, check the battery cables first.
01ragtop
May 3, 2011 06:40 PM
mikehotel
Feb 6, 2011 10:25 PM
eazyrider
Jan 20, 2010 08:25 PM
JohnT
Aug 2, 2009 09:30 AM
bobbsterkid7
Oct 8, 2007 01:21 PM
