Plug wire arcing
Old Jun 24, 2008 | 04:46 PM
Booey424's Avatar
Booey424
Default Plug wire arcing
I have a 2003 883r.I was out riding today and the bike started backfiring and sputtering.I got it home and pulled in the garage.It was dark in there&nbsp\\; and I look at the motor and the plug wire for the rear cylinder is arcing.It is doing this right at the coil.From the rubber boot to the top of the motor.Do i need new wires?Or coil?Any help would be great
Old Jun 24, 2008 | 05:24 PM
ChefE's Avatar
ChefE
Default RE: Plug wire arcing
I'd be tempted to replace both if that happened to me.&nbsp\\; Or, replace the wires first to see if that solves it (the cheapest way).&nbsp\\; If it still does it, replace the coil.&nbsp\\; If still doing it, drop back 10 and punt.&nbsp\\; Of course this is just my uneducated, non-mechanic opinion.&nbsp\\; Hopefully someone will come along that actually knows what they are talking about.
Old Jun 24, 2008 | 05:28 PM
Gpsjr10's Avatar
Gpsjr10
What chefe said.... you may have a bad wire, but if there is a crack in the coil case, you will need to replace the coil.
Old Jun 24, 2008 | 06:20 PM
SpursDarkrider's Avatar
SpursDarkrider
+1, replace the coil wire first, then if it still arcs, replace the coil.
Old Jun 27, 2008 | 02:55 PM
Booey424's Avatar
Booey424
Well I got a set of Accel wires and that did the trick.Thanks for the help
Old Jun 27, 2008 | 03:00 PM
ChefE's Avatar
ChefE
Good to hear you got it sorted out.
thumbbuster
Nov 9, 2017 03:12 PM
SwiftyBKells
Mar 30, 2013 04:44 AM
Brutus01
Apr 6, 2012 11:55 AM
ShadowSoldier777
Engine Mechanical Topics
Jun 2, 2011 02:57 PM
1200efi
Ironhead
Nov 12, 2009 05:34 AM
