Help with diagnostic codes
Old Jul 7, 2008 | 07:55 PM
EricM's Avatar
EricM
Default Help with diagnostic codes
Ok so I was able to get the codes off of my bike but now need help figuring them out.
OK under the first setting:
P: Carb code P0373= CKP sensor intermittent carb. CKP being crank position sensor.
Does that mean I need a new crank position sensor?
S: turn signal was clean of codes
SP: speedo code U1016 the only one I think pertains to me is loss of vehicle speed
I have been told that I am running about 10mph slower than my speedo says.
How do I fix that?!?!
T: tach code U1016 the same as speedo: loss of vehicle speed.
How do I fix that?!?!?
All of this started after I had the bike tuned with the TC88A. Could this be the problem? Can I take it to the dealership without them voiding my warranty for the ignition?
Thanks in advance for any help.
Eric
Old Jul 7, 2008 | 08:08 PM
WRAITH's Avatar
WRAITH
Default RE: Help with diagnostic codes
Do you use a pressure washer to clean your bike? Check your connector,you may have gotten water in it.
Old Jul 7, 2008 | 08:33 PM
EricM's Avatar
EricM
No, no pressure washer. What connector are you talking about, the connectors for the speedo and tach?
Old Jul 8, 2008 | 04:13 PM
EricM's Avatar
EricM
any suggestion?
19JMan70
Apr 11, 2014 06:03 PM
Tattoo_u
Sep 18, 2013 04:03 PM
emperor wurm
May 12, 2013 11:25 AM
eshayne
General Topics/Tech Tips
May 5, 2009 07:47 PM
petdoc94
May 11, 2008 10:05 AM
