Backfiring
Old Jul 8, 2008 | 04:41 PM
dmb2002's Avatar
dmb2002
5th Gear
Default Backfiring
I just had to start another login name for some reason. Everytime I tried to post something it would give me an error page. Oh well.
&nbsp\\;
I have a 2001 XL1200C with SEII slip-ons, hypercharger. I am not sure if there has been any carb work done either.
&nbsp\\;
The bike is backfiring on every down shift as well as when i let up on the throtle. Someone suggested I try using a hotter plug. I have not tried that yet though. If that is a good option what plug should I get, I am currently using the standard plugs for the bike.
&nbsp\\;
Any other suggestions would be great.
Old Jul 8, 2008 | 06:07 PM
jdvorchak's Avatar
jdvorchak
Default RE: Backfiring
did it just start this or has it always done&nbsp\\;it? Usually a backfire, on gear shift or reducing the throttle and&nbsp\\;NOT under accelleration, is caused by unburned gas in the exhaust system mixing with oxygen (plain air) and exploding.
&nbsp\\;
Check that the clamps on the mufflers are tight and look for tell tale signs of an exhaust leak both at the head and muffler connections.
&nbsp\\;
Are the baffles in there or did a previous owner remove them? Some times enough cold air can be sucked in the back of the muffler to let the unburned gases&nbsp\\;ignite if the baffles are removed.
Old Jul 8, 2008 | 10:33 PM
LoneRyder's Avatar
LoneRyder
Replace your intake seals.&nbsp\\; Guaranteed.
Old Jul 9, 2008 | 07:12 AM
dmb2002's Avatar
dmb2002
5th Gear
ORIGINAL: LoneRyder
Replace your intake seals.&nbsp\\;\\\\\\; Guaranteed.
&nbsp\\;
What is the easiest way to replace the seals? I do have the the service manual at home.
Old Jul 9, 2008 | 07:35 AM
dmb2002's Avatar
dmb2002
5th Gear
Sorry I am just testing something. I am having some problems. I am not able to edit my profile to add my picture. Just testing to see if I can still post.
Old Jul 9, 2008 | 10:48 AM
Sick1200's Avatar
Sick1200
ORIGINAL: dmb2002
ORIGINAL: LoneRyder
Replace your intake seals.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; Guaranteed.
&nbsp\\;\\\\\\;
&nbsp\\;
Remove carb, and replace seals on the Y.
flyboyron
Aug 2, 2008 07:22 AM
94 ultra
Jul 26, 2008 08:00 AM
whitee
Jul 16, 2008 09:06 AM
Spanish Flyer
Jul 4, 2008 01:58 PM
SloChicken
Jul 3, 2008 05:19 PM
