Tire pressure
Old Aug 8, 2008 | 08:43 AM
RMT's Avatar
RMT
Default Tire pressure
I got my 07 883C used and I didn’t get the manual that tells me stuff like tire pressure. What is a good psi to run for a solo 195 lb rider in 100 degree heat? I am planning on going on a ride with a few other guys almost down to the coast this weekend and thought it would be a good idea to check the tires.
Old Aug 8, 2008 | 08:47 AM
ChefE's Avatar
ChefE
The manual for my '06 883 says 30 front 36 rear for solo and 30 front 40 rear for 2-up.
Old Aug 8, 2008 | 10:36 AM
SportyPig's Avatar
SportyPig
That is the correct pressure, assuming you are still running the stock Dunlop tires. Other brands of tires vary.
Old Aug 8, 2008 | 12:31 PM
sbergloff's Avatar
sbergloff
I read MAX 41 PSI on the tire, so I have been keeping mine both at 41 PSI. Never checked the manual. Is that not the right way to do it? Mine is a 1200, but should not be any different I think.
Old Aug 8, 2008 | 12:34 PM
ChefE's Avatar
ChefE
I always go by the pressure listed in the manual for both the bike and my car. I always figured they know what the best tire pressure is.
Old Aug 8, 2008 | 12:37 PM
sbergloff's Avatar
sbergloff
Good point. I'll check in my manual when I get home.
Old Aug 8, 2008 | 12:51 PM
HDXXX's Avatar
HDXXX
I would go with 40 PSI
Old Aug 8, 2008 | 12:56 PM
Gpsjr10's Avatar
Gpsjr10
The recommended tire pressure and tire size is listed on the sticker on the right side on the front part of the frame. At least it's there on my 02 Hugger and my 08 Nightster
Old Aug 8, 2008 | 01:39 PM
cHarley's Avatar
cHarley
Never use the Max pressure on the tire sidewall. It is what it says, not the recommended pressure which is based on GVW, (Gross Vehicle Weight).
The tire pressure listed in the Owners Manual is correct for the stock Dunlop tires. You will notice in the manual that the recommended rear tire pressure is different for 2up vs. solo.
If you are not running the stock Dunlop tires, you need to refer to the tire manufacture for the correct pressures for your model bike. This can usually be found on the mfg's web site.
Old Aug 8, 2008 | 02:01 PM
JosephGarcia's Avatar
JosephGarcia
i have 1988 and the sticker on the frame says 26 rear 32 front
i run 40 both and get longer tire life and better handling. at 26 and 32 it feels wiggly
