Engine Guard XL 1200C
Old Aug 8, 2008 | 01:20 PM
Curt1953's Avatar
Curt1953
Default Engine Guard XL 1200C
How hard is it to put a engine guard on XL 1200C. Dealer says half hour labor charge at $38.00. Does it come with all the mounting bolts or does it bolt to bolts thats already on the bike.
Old Aug 8, 2008 | 02:18 PM
plysat's Avatar
plysat
I assume it's the same as a 1200N so... really easy. The HD kit comes with bolts. I'd suggest getting a torque wrench (and blue loc tite!) cuz the upper bolts replace the ones for the upper motor mount. Your call though... takes about 10 or 15 minutes...
Old Aug 8, 2008 | 04:19 PM
sastrac's Avatar
sastrac
It's not too bad to install. The bolts on the upper motor mount are kinda hard to get a socket in. Mine where really cranked on tight. Depends how mechanically inclined you are. $38 is not a bad price.
Curt1953's Avatar
Curt1953
Well I just found out from my dealer that they are on back order untill the end of the month, and thats after paying for them last Thursday and being told they will be here yesterday.
Old Aug 8, 2008 | 04:38 PM
plevine1's Avatar
plevine1
Super easy to install. Only hard part is holding them in place while threading the bolt. The bar is heavy.
Old Aug 8, 2008 | 04:45 PM
ayebyte's Avatar
ayebyte
SIMPLE ...save yourself and wrench on your own.
Old Aug 8, 2008 | 05:15 PM
ChefE's Avatar
ChefE
I put one on my 883 in the dealer's parking lot. Took about 15 min.
Old Aug 8, 2008 | 05:25 PM
steelhead's Avatar
steelhead
If you have some tools, I would say go for it yourself. I put one on the wife's 883L and it was a straight operation. With the custom models it will be even easier as you don't have to mess with the horn.
Old Aug 8, 2008 | 09:29 PM
carlo's Avatar
carlo
Just cover the front fender with towel so you don't scratch it. When I removed one of the upper bolts it was striped I used the same bolt in the same hole and torqued it to spec no probelms bolt stays tight if it diden't I would of tapped it.
Old Aug 8, 2008 | 09:39 PM
Curt1953's Avatar
Curt1953
Thanks all, lots of good advice here. Now I just have to wait till the end of the month to get it, must be a big run on engine guards out there.
