Burnt leg?
Old Aug 12, 2008 | 12:47 PM
sbergloff's Avatar
sbergloff
Originally Posted by hogsport
Sounds like you are flat footing (and maybe a little short legged) with both feet. Try the motocop practice of only lowering your left foot, keeping your right foot on the peg / rear brake. I find it a good practice and makes uphill starts much easier also. It is hard to burn your leg if your foot is on the peg.
I was about to suggest the same thing. I have never burned my leg on my bike, but I do this sometimes at lights so that the bike doesn't roll any.
Old Aug 12, 2008 | 12:51 PM
harleychicknj's Avatar
harleychicknj
You are correct. I'll have to try that out next time I am out and about.
Thanks!
Old Aug 12, 2008 | 02:41 PM
Moiraes Snag's Avatar
Moiraes Snag
I've never burned my leg, but I'm 5'1" and I have a permanent bruise on my left leg from my foot peg (Nightster, mid-controls.) Still can't figure out when I'm hittin' it. Never had this problem with forward controls.
Old Aug 12, 2008 | 03:40 PM
CapnAdventure's Avatar
CapnAdventure
Maybe you keep hitting it when backing up? When doing so, put the peg up first.
Old Aug 13, 2008 | 10:51 AM
Moiraes Snag
Yep, started doing that, but only manage to remember half the time.
I'm thinking about growing a little taller, maybe that will help.
Old Aug 13, 2008 | 11:18 AM
Slaps's Avatar
Slaps
It couldn't hurt .
Old Aug 14, 2008 | 07:55 AM
bmxatv's Avatar
bmxatv
you should always wear pants. how bout wrapping those pipes up?
Old Aug 14, 2008 | 08:31 AM
rh8234's Avatar
rh8234
It's easy to explain to folks how you burned a leg on the pipes, but just try explaining a huge burn/blister on the forehead! I got the bike (Dyna) good and hot, then bent over to check trans fluid. Rested my forehead on the pipe for a second. I looked rediculous with a big scabby forehead for a few weeks. Live and learn!
Old Aug 14, 2008 | 08:40 AM
HarleyScuba's Avatar
HarleyScuba
There was a recall on some Sportster exhausts. Peoples' jeans were getting burnt. A new/different heat shield is the fix from The Motor Company. Have your dealer run your VIN (just call 'em w/ the VIN) to see if your bike is on the recall list.
Good luck.
Old Aug 14, 2008 | 08:50 AM
Moiraes Snag
Good luck.
If I recall, the recall was on 2007 models.
