nightster shock question
Old Aug 14, 2008 | 01:52 PM
nightster1212's Avatar
nightster1212
Anyone have a definate answer on this?
Old Aug 14, 2008 | 02:07 PM
JRK5892's Avatar
JRK5892
they will fit no prob! i have them on my bob and just LOVE THEM!
Old Aug 14, 2008 | 03:32 PM
Elvis Nixon's Avatar
Elvis Nixon
You can do the air fill system one of two ways.
#1) Buy the airhose kit from HD like the baggers use. You also have to buy HD's special hand pump for the to work but it automatically fills both shocks to the same exact PSI. You'll also need to find a place to route all the airlines and air fittings.
#2) Go to NAPA and get what they call an "air tank valve" which is a threaded Schrader air valve. Thread those into the top of each shock using teflon plumber's tape. Now you can use a standard bicycle pump to add the desired PSI to each shock. Don't overfill!! 5-10 PSI is a ton in these shocks. Using a good digital tire gauge that reads in the tenths of a PSI helps to get both shocks filled the same.
I used method # 2.
Old Aug 14, 2008 | 03:37 PM
Elvis Nixon
Here's a link to the part you need at the NAPA site. Most NAPA stores have them on the shelf near the tire repair stuff.
http://www.napaonline.com/MasterPage...ion=Tank+Valve
Old Aug 15, 2008 | 06:58 AM
nightster1212
Thanks Elvis
Is it very hard to get the right PSI filling them individually? This is probably going to be a winter project so getting everything set up and figure out where to put everything will not be a problem
Certainteed
Feb 2, 2020 07:36 AM
103megawatt
Feb 27, 2013 09:03 AM
jdf9
Apr 21, 2012 05:40 PM
sorensentyler
Feb 14, 2010 04:31 PM
glarior
Jul 15, 2009 03:50 PM
