Big Problem NEED HELP ASAP!!
Old Aug 25, 2008 | 08:20 PM
Bacon_Grease's Avatar
Bacon_Grease
Why not simply hotwire it? It's stupid easy on a motorcycle.
Old Aug 25, 2008 | 08:31 PM
BriXL04's Avatar
BriXL04
no fob or anything
Old Aug 25, 2008 | 08:34 PM
liddown's Avatar
liddown
When you turn the key on does the red key light come on and stay on, or does it go off and come back on and stay on... The key light is also tied to diagnostics for the turn signal module and the serial data bus.... But knowing the lighting sequence is important to knowing what the light is telling you...
Old Aug 25, 2008 | 08:35 PM
BriXL04's Avatar
BriXL04
still nothing
Old Aug 25, 2008 | 08:36 PM
racinorange's Avatar
racinorange
if you don't have a security system, sounds like a fuse to me...I blew my main fuse once on a trip, 200 miles from home...found a paper clip on the side of the road and put it in place of the fuse...BIG mistake...fuses blow for a reason I found out...melted the entire wiring harness!!! yikes! Anyway, check your fuses...
BriXL04's Avatar
BriXL04
the light only comes on when you hit the start button.. and then stays on.. ill be right back my buddy just blew out his front tire over some tracks.. so i have to pick him up.. give me 30 mins thanks guys you all are big help
Old Aug 25, 2008 | 09:28 PM
BriXL04's Avatar
BriXL04
ill check the fuses... where are they all at?
Old Aug 25, 2008 | 09:48 PM
BriXL04's Avatar
BriXL04
alrighty i got it to start.. there was a blown fuse... but now the check engine light is on.. and it still doesnt sound right.... but better then b4....both plugs have spark... and good fuel.. i would like to think there is a short somewhere else too but i'm to too sure.. what could be causing the check engine light to come on?
Old Aug 25, 2008 | 10:45 PM
JosephGarcia's Avatar
JosephGarcia
bad grounds at the coil connections or anything you touched or replaced since the original problem happened
also battery connections
did you replace your plugs?
Old Aug 25, 2008 | 11:40 PM
Nightster_Reaper's Avatar
Nightster_Reaper
the plugs have spark but wat condition are they in? also what about the plug wires? unless u have a service manual u mite wanna take it to the dealer so it doesnt shut down on you again. yea i asked if you bought it used because i thought maybe they put security on it and hid the fob somewhere. also the battery could have been dead in the fob. but it def. is an electrical problem so check the basic areas such as plug wires. if its not idling properly then the plugs could be in bad shape or a short somewhere else.
