Big Problem NEED HELP ASAP!!
Old Aug 25, 2008 | 07:35 PM
BriXL04's Avatar
BriXL04
Default Big Problem NEED HELP ASAP!!
2004 sportster roadster 1200
Alrighty first off i was riding last night and my coil shorted out and lost the rear cylinder spark.. it ran for a short time.. then died... and would not start..
I got a new coil pack today.. and put it in.. then tried to start it.. and i go no response at all.. battery is charged... there is a little red key that came on on the speedo.. my guess is that it locked me out.. HOW DO I FIX THIS!! PLEASE HELP!!!
This is my only way to work.. and i'm SOL if i dont get it going
thanks for your help!
Brian
Old Aug 25, 2008 | 07:43 PM
Nightster_Reaper's Avatar
Nightster_Reaper
lol the lil red key is for security systems i believe. do you have one? perhaps the remotes battery died so its not getting a signal from key fob. thats all that lil red key means im pretty sure. did you check the plugs to see if they are fouled out? did you buy the bike useD?
Old Aug 25, 2008 | 07:52 PM
BriXL04's Avatar
BriXL04
yes i bought it used... but it was a demo.. with only 391miles on it.. but no i do not have any alarms or anything like that on there... i turn the key and hit the start and have no response...
Old Aug 25, 2008 | 07:55 PM
georgiabiker's Avatar
georgiabiker
The key is the security system, I don't know if it is tied in with the coil. You may need to call a indy or stealer.
Old Aug 25, 2008 | 07:58 PM
BriXL04's Avatar
BriXL04
but it doesnt explain why i have nothing at the start button.. unless there is a blown fuse.?
Old Aug 25, 2008 | 08:02 PM
zonplyr's Avatar
zonplyr
nothing when pushing start does sound like a security system thing. the key should flash when armed, not stay steady. i don't have my manual in front of me but there is a way to reset the security system. something similar to cycling the key 3 times and then hitting the left turn signal or something like that. sorry i'm not more help but it sounds to me like a security system lock out.
Old Aug 25, 2008 | 08:06 PM
BriXL04's Avatar
BriXL04
ok i will try that thanks ill let you know in a few mins
Old Aug 25, 2008 | 08:10 PM
BriXL04's Avatar
BriXL04
nothing..
Old Aug 25, 2008 | 08:15 PM
zonplyr's Avatar
zonplyr
does your bike have a key fob with it? if it is the fob with the button i think hitting the button twice (quickly) will enable the starter again (turn off the security system). If it's not the type with a push button fob then you need to go through the other sequence.
Old Aug 25, 2008 | 08:19 PM
zonplyr's Avatar
zonplyr
oh, and i think the reset procedure is on/off/on/off/on left turn signal. Somebody here must have their manual in front of them. sorry i'm doing this from memory.
