Stage 1 "Kit"???? There are no exact "kits". You say you already have the new pipes, (which you could install), but you don't mention an AC. Stage 1 is a high flow AC & exhaust and a download for EFI or re-jett for carbs. Also, some people say that the full Stage 1 also includes an upgrade to the ignition.
I think what he is trying to get at is you could easily swap out the pipes and air cleaner of you choice and only have to pay for the download. I recommend getting a set of snap ring pliers (C-clip pliers would be a good idea also) prior to putting the pipes on, other than that, follow the instructions and you should be able to get it done in a couple of hours.
