1200C Backfire
Old Sep 25, 2008 | 07:54 AM
smakcaine's Avatar
smakcaine
1st Gear
Default 1200C Backfire
My 1200C Sporty sometimes backfires when starting. Any suggestions on what may cause this? Could it be a simple as changing sparkpluggs or something more complicated.
Old Sep 25, 2008 | 08:03 AM
CapnAdventure's Avatar
CapnAdventure
What year is it? I have an 07 efi and if you blip the throttle before it is fully warmed, it will sometimes backfire, so I'm careful to make sure it's fully warmed b4 riding off.
Old Sep 25, 2008 | 08:18 AM
schumacher's Avatar
schumacher
yep, year would help.
and welcome to the forum
Old Sep 25, 2008 | 12:33 PM
smakcaine's Avatar
smakcaine
1st Gear
Sorry about that, it is a 1999.
Old Sep 25, 2008 | 12:34 PM
Zimbob's Avatar
Zimbob
My '02 would do the same thing, occasional backfire when starting, maybe 1 in 500 starts, but only when warm. Most of the pre EFI bikes I know of do it to.
Sick1200's Avatar
Sick1200
What kind of carb do you have? Do you have baffles in your pipes? How long has it been since you started it?
Old Sep 25, 2008 | 01:04 PM
6o66er's Avatar
6o66er
Is it backfiring out the carb or the pipes? Could be time to rebuild the carb....or just have it fine tuned.
Old Sep 25, 2008 | 01:19 PM
smakcaine's Avatar
smakcaine
1st Gear
It has shotgun pipes with no baffles. I believe it is backfiring through the pipes.
Old Sep 25, 2008 | 01:26 PM
6o66er's Avatar
6o66er
Unused fuel...you're running rich. Rebuild and re-tune the carb. Mine used to do that alot....it could also be because you've got **** pressure from running with no baffles. If they're larger diameter pipes, I HIGHLY recommend running baffles. I put a set of BCT's in my 2" drags and I honestly haven't touched or worried about ANYTHING since I had it tuned at the beginning of the year. No pop, no carb fart, no NOTHING...it runs perfect. EDIT: Loud as a mother-****er, too.
Just a thought.
Old Sep 25, 2008 | 02:59 PM
smakcaine's Avatar
smakcaine
1st Gear
Will running rich cause the resisdue inside the pipes to be a brownish color instead of black.
