Shock Length
Old Mar 31, 2006 | 12:58 AM
akrefugee's Avatar
akrefugee
Stage III
Default Shock Length
I have a 05 1200 Custom and want to get rid of the so called "shocks".
I am looking at the Progressive 412's. I want to stay with the same height
on the bike but can't seem to find out what length the stock shocks are.
Any one know what it is???
Also how hard is it to put them on myself. Any suggestings or hints on making it easier. (other then having my local stealer do it)
Old Mar 31, 2006 | 01:43 AM
AZFlyingDiver's Avatar
AZFlyingDiver
Default RE: Shock Length
11.75" eye-to-eye for '05 Customs.
Either 11.5" or 12" Progressives...
(I went lower with 11")...
EDIT (how I mounted them):
Top Mount (in order): bolt, OE washer, OE chrome cover, top shock eye, Progressive spacer insert facing inward, Progressive zinc washer, Progressive fat spacer, all twisted into the bike's top mounting point.
Bottom Mount (in order): bolt, OE washer, Progressive spacer insert facing outward, bottom shock eye, Progressive zinc washer, Progressive fat spacer, bike's mounting point, OE nut.
Your spacing may vary (just need to find a combination that results in your shocks being vertically straight). It's pretty easy, actually. And the Progressive kit comes with decent instructions and the spacers you'll likely need.
Good luck!
Old Mar 31, 2006 | 11:32 AM
akrefugee's Avatar
akrefugee
Stage III
Hey AZ, Thanks that will help a lot. I have 36" legs so will probable go with the 12"
Old Mar 31, 2006 | 03:08 PM
1200c's Avatar
1200c
You can also get away with 12.5 inches if you want without changing the lines of the bike too much. The 12.5's will give you quite a bit more travel.
Bobby12012
Apr 11, 2016 08:23 PM
Agiuliano10
Jul 7, 2013 12:53 PM
OutlawBagger
Jan 21, 2009 08:33 AM
ssls6
Nov 25, 2007 11:48 AM
dirt_dobber
Jun 15, 2006 12:30 AM
