vibrations
Old Oct 10, 2008 | 07:13 AM
Ramboamt's Avatar
Ramboamt
Originally Posted by ashenfang
Hey guys, maybe I am just being to nit picky, but thought I would ask. (I tend to notice things they may have always been there, but just now notice them) I basically just want to make sure its normal. When out riding on my 883, 0-MPH is pretty smooth, but once I start getting above MPH I start to feeling some pretty intense vibrations, especially in the forward control area, up through the bars. Does this seem normal? I can't really tell if its engine or bike vibrations. It doesn't matter if I am in Th or Th gear, I still have the same results.
Have the front wheel balance checked. I have the cast wheel on my '06 XL1200C and it has the stick on balance weight similar to the ones used on your car. As you increase the speed the out of balance problem will increase.
Old Oct 10, 2008 | 01:34 PM
Healey2Harley's Avatar
Healey2Harley
The sporty will definately shake and rattle if you try to accelerate at 50 mph in 4th or 5th gear. The power band is around 3500 rpm which is about 50 mph in 3rd. Wind it up a little more and see if seems a lot smoother. I dont usually use 5th until 65.
Old Oct 10, 2008 | 09:43 PM
Black No.1's Avatar
Black No.1
My '08 Nightster does the same thing at the same speed. It goes away at 61 mph. My fiance's '03 1200C doesn't do this. I'm thinking most of you guys are right about the lugging. Sportys like to run at a little higher RPM. In addition to the slight lugging at that speed, in that gear, i think it also has do with the rubber mounted engine. Hers is rigid mounted.
gypsy.crushr
Dec 5, 2017 10:53 AM
rockie
Jul 31, 2016 10:14 AM
usafa83
Jul 8, 2015 12:24 PM
Nova Joe
Sep 3, 2012 09:42 PM
RoadKingKamchi
14
Jan 1, 2009 08:50 PM
