Intermittent rough running
Old Sep 2, 2012 | 07:26 PM
Nova Joe's Avatar
Nova Joe
Stage III
Default Intermittent rough running
'06 Low Rider. Bought new and at 49 miles, bike died and wouldn't start. Taken care of under warranty and while bike in shop, had a Stage 1 installed; air cleaner, pipes (just before HD stopped production), and module (magic box to meter fuel or some such thing).
Drove the next 500 miles never exceeding 2,000 rpm (as instructed by dealer) for break-in. Changed all lubricants (used 100% synthetic) at 500 miles and began 'normal' riding. Immediately experienced pretty severe vibration at 2,200 rpm (regardless of what gear I was in) and a much milder vibration again at 2,800 rpm. Spent the next two years going back and forth to dealer(s) with no resolution. Warranty ran out and was basically told there was nothing that could be done, the bike was ok.
What I am looking for now are some ideas/suggestions as to where the problem may be.
Here are the symptoms. The problem with the problem is that it is intermittent. When running well, it's sweet. Smooth, good throttle response and a pleasure to ride. When not running well, it sounds like it's only hitting on one cylinder or ignition or fuel is late and throttle gets little response until opened a considerable amount. Even then, it sounds like the engine is struggling and with two up, I find I need to downshift one or two gears. No indication of knock or pre-ignition. When running well, it'll pull a fairly steep grade in 6th gear even with two up
The problem does not seem to be temperature related; I can start a ride running fine and without anything different, starts running poorly and it may continue or begin running like it should.
My local HD parts guy thought it might be this add-on controller so I took it off. The symptoms are not as severe as they were but are still there.
I am at a loss as to what to do (other than get rid of the bike) as are three HD dealers but I'm hoping someone out there has some ideas.
Any thoughts or suggestions would be greatly appreciate.
Thanks for your time.
Old Sep 2, 2012 | 09:17 PM
nevil's Avatar
nevil
Did it throw any codes?
Old Sep 3, 2012 | 08:31 AM
Nova Joe's Avatar
Nova Joe
Stage III
Apparently not...or at least I would think the dealer would've picked up on that. But then I had one dealer determine the cause was the windshield so I'm not sure how much stock yo put in what a dealer says.
I've been told the incorrect injectors were installed with the stage 1 so they were replaced. Same dealership also replaced engine mounts (different visit). Another dealer said it was tire pressure and steering stem bearing adjustment. In every case, I've made it clear the problem is rpm related NOT speed.
A fourth dealer (without seeing the bike) determined the problem was I needed to install a new module (an HD something or other) along with their expert tuning and for a mere $900, my problem would be resolved.
No mention of codes bt anyone.
Finally, the last word from the original dealer was that the Dyna engine/chassis is not as smooth as the bigger bikes...that's just the way it is.
Thanks for your reply and having the code history looked into sounds good but not really sure where to take the bike.
Old Sep 3, 2012 | 09:24 AM
nevil's Avatar
nevil
You don't have to take it anywhere. Here's how:
https://www.hdforums.com/forum/elect...tic-codes.html
Old Sep 3, 2012 | 09:42 PM
Nova Joe's Avatar
Nova Joe
Stage III
Nevil, I thank you. A quick glance and it looks a bit intimidating but anxious to go over it again in the morning and give it a try. Not a dummy, mech engineering, but for some reason, I get around anything remotely resembling a computer and evil forces enter my domain.
I'll let you know how it goes.
Your help is most appreciated. Thanks.
Blackfly
Sep 10, 2013 07:14 PM
kp050
Sep 26, 2010 02:34 PM
Phil K
Sep 20, 2008 09:07 PM
MTNLADY
Welcome Area Only
11
Sep 5, 2006 03:10 PM
arachman
Jun 2, 2006 10:04 AM
