Exhaust Problem
Old Oct 19, 2008 | 08:20 PM
plevine1's Avatar
plevine1
Default Exhaust Problem
I have an 06 Sportster Custom with just under 30k miles on it. I recently noticed some black dirt around where the pipe connects to the manifold. Starting with the cheapest and easiest possible causes and solutions.
1. Is there a gasket between the pipe and the manifold? Along with tightening the bolts it might be a good thing to change the gasket considering the mileage.
2. In the event that it’s a head gasket, can this be determined before removing the tank and pulling the rocker box covers?
Old Oct 19, 2008 | 08:30 PM
cHarley's Avatar
cHarley
Yes, there is a manifold gasket there and it's likely the problem. When you pull the exhaust pipe off it may not be obvious but it's in there and you usually have to dig it out of the head. When you pull the old ones out they look kinda like a ring of packed steel wool. When you replace them, it's worth it to use the Harley "SE" gaskets.
Old Oct 19, 2008 | 09:47 PM
WRAITH's Avatar
WRAITH
If it was the head gasket, you would have an oily fluid (smells like gas) forming on your cooling fins. I just replace the head gasket on the front cylinder. It sounds more like an exhaust gasket leak. The gaskets are inexpensive and easy to replace. Sometimes you can get away with re tightening the nuts, don't over do it they can snap.
Old Oct 19, 2008 | 11:16 PM
mrb302's Avatar
mrb302
+1
I went with the SE's this last time and they hold together better than the stockers. If you believe the SE hype they also flow 8% more than the stockers.
Old Oct 20, 2008 | 08:30 AM
xFreebirdx's Avatar
xFreebirdx
Originally Posted by mrb302
+1
+2
Old Oct 20, 2008 | 01:54 PM
plevine1's Avatar
plevine1
I checked the two bolts holding the pipe to the manifold and one was loose. I think I will still replace the gasket on both pipes. What the heck. It's easy enough and after 30k miles a little prevention is worth it.
Does anyone know the part number for the SE gasket?
znewberry
Exhaust System Topics
Oct 27, 2012 06:13 PM
jm04
May 31, 2011 03:09 AM
deadreckoning
Shovelhead
Mar 26, 2009 02:35 PM
wico1
Jun 8, 2007 08:17 AM
wingt50dw
Apr 29, 2006 08:37 PM
