Mini Apes cables???
Old Nov 16, 2008 | 03:48 PM
congo_usmc's Avatar
congo_usmc
Default Mini Apes cables???
I have an '05 1200 custom, i just got a mini ape handlebar. does anyone know what cables i need to replace and the lengths? im trying to find them online but i just dont know what cables will work with them. thanks - Joe
Old Nov 16, 2008 | 04:00 PM
RATROD HOG's Avatar
RATROD HOG
J&P cycles
stock plus 6" over
Old Nov 16, 2008 | 04:02 PM
RATROD HOG's Avatar
RATROD HOG
Brand: Barnett cables
Old Nov 16, 2008 | 05:54 PM
dlg1125's Avatar
dlg1125
Magnumshielding.com, they are the people who make black diamond cables for harley, and for allot cheaper I might add.
David
Old Nov 16, 2008 | 09:24 PM
Flatlander's Avatar
Flatlander
I'll second magnumshielding. As for cables-throttle, idle, front brake line, clutch and extend wiring. To get length, have someone hold bars at approximate mounting location and run string from bars and measure. Probably 4-6" over, but I would measure just to make sure.
Old Nov 17, 2008 | 07:25 AM
rh8234's Avatar
rh8234
Never mind - I'm still asleep and answered as though it was a Dyna you were asking about. sorry about that.
Old Mar 9, 2009 | 12:11 PM
fyrmnjim's Avatar
fyrmnjim
Would I need to go +2 on the lengths?
Old Mar 9, 2009 | 02:50 PM
capttawes's Avatar
capttawes
No, +6" generally works but you should mount your bars then measure which is what I did. I'm using minis on 3" straight risers and have 59" clutch, 44" brake line, and 38" throttle/idle cables which is what worked best for me. Actually the clutch could be longer so I could rout it through the trees vs. behind them.
Old Mar 9, 2009 | 04:49 PM
fyrmnjim's Avatar
fyrmnjim
Thanks Cap, I'm ordering mine from magnum, but they weren't sure of the lengths when I called them.
Temporary Username 1
Nov 2, 2013 11:06 PM
99%r
Aug 5, 2013 10:00 PM
1nuckenfut
Jun 24, 2011 09:54 PM
pedigree44
Softail Parts
Apr 24, 2011 11:22 AM
Skip
Feb 3, 2009 08:38 AM
