Speedometer Question
Old Nov 25, 2008 | 06:37 PM
chromedome's Avatar
chromedome
Default Speedometer Question
Will an 08 1200c speedometer fit in an 08 1200L housing?(son is doing an ape install and would like to use the whole 1200L set up) I ask because it looks to be the same diameter but looking externally at the housing of each, the 1200c housing is deeper than the 1200L. I'm wondering if the speedos are the same depth and the 1200C just has added housing depth for appearance or something.
Old Nov 25, 2008 | 07:37 PM
GazzaTheBastard's Avatar
GazzaTheBastard
The second most important add on you can ever buy for your sportster from the harley
davidson dealer, right after the factory service manual, is the parts manual !!!!
You can get them both for less than $100 and they'll pay for themselves in just a couple
months time. Nothing else you can ever buy from them has as much value !!
I don't have and never will need an '08 manual, but historically they have always been
the same. They're different between 883 and 1200 because of the different drive
sprocket gearing which comes after the sensor.. but they're the same physical size for
all models any given year.
Gazza
Old Nov 25, 2008 | 07:40 PM
RATROD HOG's Avatar
RATROD HOG
just look in parts book and it shows speedo only is the same part # for both custom and L
any ? give a shout no problem,i like when he or her takes the bike to the next level
RATROD HOG
Old Nov 25, 2008 | 09:47 PM
chromedome's Avatar
chromedome
RATROD HOG
Thanks Gazza. Thanks Ratrod. He's putting on 16" narrow glide apes. Looks like he'll be using the 1200L Speedo housing and riser set up. Gonna have it powder coated black as he is using black apes and powder coating his fork lowers black as well. We'll be off to Harley tomorrow to get part numbers unless you might know what he needs. ? I guess at minimum it is the housing which is built into the riser top clamp, riser boltss, speedo bezel, O-ring or vibration gasket, riser bottoms and the 5 (or 6) hole top cover plastic piece that the leds come up into. I'll probably order fromChicago Harley to save some $ and time.
Old Nov 25, 2008 | 10:04 PM
RATROD HOG's Avatar
RATROD HOG
sounds like you got it all together there.
Old Nov 25, 2008 | 10:16 PM
RATROD HOG's Avatar
RATROD HOG
here is a couple shots of old set-up
Attached Thumbnails Speedometer Question-dscn0077.jpg   Speedometer Question-dscn0081.jpg
Old Nov 25, 2008 | 11:15 PM
chromedome's Avatar
chromedome
any pics of your new set up?
sajor
Dec 24, 2014 08:47 PM
sajor
Dec 15, 2014 05:18 PM
ShiftyCapone
Feb 3, 2014 06:12 AM
Roadie09
Aug 7, 2008 01:11 AM
factoryhdtech
Jun 13, 2008 03:22 PM
