COIL anybody?
Old Dec 5, 2008 | 09:39 PM
MACSTAR100's Avatar
MACSTAR100
6th Gear
Default COIL anybody?
How can I tell if my coil is going bad? Does it give any pre-signs or is it just either good or bad?? XL1200c
Old Dec 5, 2008 | 10:10 PM
rocketmangb's Avatar
rocketmangb
Default Coil
Generally either good or bad
Whats the trouble ?
Old Dec 5, 2008 | 10:13 PM
MACSTAR100's Avatar
MACSTAR100
6th Gear
it bogs down and then jumps back to full power....goes for a second and then bogs down and jumps back to full power. It feels like I am hitting the power band on a two stroke dirt bike
Old Dec 5, 2008 | 10:25 PM
rocketmangb
Default bike
what bike ?
Old Dec 5, 2008 | 10:26 PM
rocketmangb
i see
1200 c what year ?
Old Dec 5, 2008 | 11:41 PM
MACSTAR100's Avatar
MACSTAR100
6th Gear
2001 XL 1200c carbed
Old Dec 6, 2008 | 05:38 AM
dbleagle's Avatar
dbleagle
Don't sound like a coil to me...
Maybe fuel... float...
Pull any codes?
They might tell you something...
Charlie D.
Old Dec 6, 2008 | 06:48 AM
1200efi's Avatar
1200efi
A coil can fail two ways, just flat out fail and bike won't start, or it can run ok until coil gets hot and breaks down, let it cool down and you can go again until it gets hot again. If your bike does this right from the start up I would have to agree with dbleagle that it might be the fuel. Hope this helps. Ride safe.
Old Dec 6, 2008 | 08:04 AM
MACSTAR100's Avatar
MACSTAR100
6th Gear
Yea, I think yall are right. That is the way I'm leaning anyway. I thought I would at least get some thoughts on the coil. Thanks yall!
Old Dec 6, 2008 | 08:36 AM
Booey424's Avatar
Booey424
Check the wires that connect to the coil.My bike did the same thing.I changed the coil,wires,plugs,and even the ign module.It wasn't any of those things.It was the 2 cent clip that holds the wire to the coil.I just crimped it down and now it stays on all the time
