Help with trouble codes
Old Dec 24, 2008 | 07:43 AM
Sinner69's Avatar
Sinner69
Default Help with trouble codes
Does anyone happen to know what the trouble codes 1121 & 1122 mean?
I already did a search, but I don't see them listed .
Thanks
Old Dec 24, 2008 | 08:14 AM
FastHoss's Avatar
FastHoss
You did not say year of bike,but probably have to look for a 2009 code.I would change the system relay,it is probably bad or has corrosion.
Old Dec 24, 2008 | 08:40 AM
Sinner69's Avatar
Sinner69
sorry..It's a 04 xlc & the code shows up under the "S" catagory
Old Dec 24, 2008 | 09:02 AM
FastHoss's Avatar
FastHoss
Turn signal or turn sinal security module
Old Dec 24, 2008 | 09:07 AM
cHarley's Avatar
cHarley
Assuming you are leaving a "B" off the front end of the error code:
14. B1121(TSM) Left Turn Output Fault
B1121(HFSM) Left Turn Output Open
15. B1122(TSM) Right Turn Output Fault
B1122(HFSM) Right Turn Output Open
Old Dec 24, 2008 | 09:19 AM
Sinner69's Avatar
Sinner69
Ok, thanks. This makes sense then, I just changed the turn signals from the forks, to the mirrors. The mirrored turn signals only use 1 wire, so I had to dead-end the blue wire( turn signal input, I think) & the black wire(ground).
vanceandharley
Electrical/Lighting/Alarm
Jan 18, 2015 02:48 PM
pp6000v2
Sep 23, 2013 10:43 AM
pp6000v2
Sep 20, 2013 04:35 PM
DGDyna
Nov 24, 2012 04:56 PM
rhiggins
General Topics/Tech Tips
Aug 6, 2007 10:59 PM
