Gaurdian Bell
Old Jan 3, 2009 | 04:45 PM
denimnightster's Avatar
denimnightster
Default Gaurdian Bell
Where is the best place to hang the bell on a sportster???
Old Jan 3, 2009 | 04:57 PM
kahaone's Avatar
kahaone
Put it in between the rabbits foot and the 4 leaf clover, but don't get it close to the clove of garlic, or you will lose all the "spirits" from the bell.
Is it obvious that I don't put much stock in superstition?
Old Jan 3, 2009 | 05:13 PM
fixedmlc's Avatar
fixedmlc
There is a cross member on my 93 right under the voltage regulator that had a hole in the middle of it. It was perfect to get the keyring holding the bell on right there. Low in front like it's supposed to be, and out of the way of everything.
Old Jan 3, 2009 | 06:46 PM
RMT's Avatar
RMT
If you dont have an engine guard use one of the lower bolt holes for the engine guard.
Get a friend to put it on, it adds more luck that way.
Old Jan 5, 2009 | 06:10 PM
1200N's Avatar
1200N
here is mine, not low on the bike, but i wanted to see it everytime i get on.
Old Jan 5, 2009 | 06:30 PM
vet767's Avatar
vet767
Maybe you should. I should have been dead a number of times can only think my st christopher, or my bell or the prayers of my family and friends kept me here Your choice
Old Jan 5, 2009 | 06:35 PM
jwa07nightster's Avatar
jwa07nightster
put it around the lines running right above your ignition. That way you bump it everytime you start.
Old Jan 5, 2009 | 07:55 PM
killer scott's Avatar
killer scott
Mine is down low in between the two frame rails on that cross member in front of the engine. Probably a good name for that part.
Old Jan 5, 2009 | 10:20 PM
Zimbob's Avatar
Zimbob
It should go low and in the front. Didn't you get the card that explains the bell? Works better if a friend gives it to you, without asking for it, you should mount it yourself so the "luck" covers you and the bike.
Old Jan 5, 2009 | 10:24 PM
Dango's Avatar
Dango
I hang a chunk of Velveeta from my horn.
