Rear tire?
Old Jan 10, 2009 | 11:11 PM
krazedstang's Avatar
krazedstang
Default Rear tire?
hey, i was wondering how hard it would be to replace the rear tire myself? and what tools would i need if i were to do it myself
thanks Tony
Old Jan 11, 2009 | 07:19 AM
SportyPig's Avatar
SportyPig
Harbor Frieght has a motorcycle tire changing station for $100. I've thought about checking it out, but I have a guy close to me that will mount and balance a tire for $15. So, I just keep going to him.
Old Jan 11, 2009 | 07:33 AM
66impala's Avatar
66impala
Your going to need a service manual for your bike. I have a harbor frieght lift, a torque wrench and 6 point socket that fit the axle nuts. Also need a belt tension gauge and make a rod to measure distance for your rear wheel, a can of antiseize for the axle. The first time I did this it took about two hours to get it apart.
Ive never taken the tire off of the rim myself, I just removed wheels to switch out and have new tires put on by a local indy.
Old Jan 11, 2009 | 08:12 AM
capttawes's Avatar
capttawes
Pretty much as mentioned with the manual, jack and assorted tools (just need a coat hanger bent open or straight rod for measuring axle distance and alignment). Fisrt time removing the axle is an issue for most since the factory fails to put enough if any anti-sieze/lube on it so they stick severely.
For the tire change you'll need some tire irons for certain ans some patience. Here's a couple tutotrials I had savede on changing tires: http://www.clarity.net/~adam/tire-changing-doc.html#3 , http://reviews.ebay.com/HOW-TO-CHANGE-AND-BALANCE-TIRES-ON-YOUR-MOTORCYCLE_W0QQugidZ10000000003224358
I've had my wheels off a lot and change my own tires (in fact the rear wheel is off now while I paint the rear pulley and polish the brake rotor). While not difficult its not super easy either (the tire part).
My problems with indys and dealers is that many now don't install tires that you did not buy from them and if you buy from them the price can be quite high or they also charge an install fee. Round here the install fee is free to around $15-20 per if you buy the tire from them and those that will do it with you bringing in a tire purchased elsewhere charge $25-50 at least per tire. So essentially if you buy online cheap and learn to do it yourself the savings can be substantial enough and the only downtime vs. taking your bike or just wheels to the shop is the amount of time it takes you to change it.
But the way, a tip for protecting your rim against the tire irons is taking a section of garden hose and slitting it open ans using it around the edge while working th ebead over with your tire iron. If you find yourself changing tires often then invest in the cheap tire changer.
Old Jan 11, 2009 | 10:15 AM
Willie D's Avatar
Willie D
Post changing tires
the guys have given you some good advise and not knowing your mechanical abilities, my suggestion would be, if you have the tools and a lift already. take the tire off and take it to your local shop and let them do it. you are not going to need to do this every month so save yourself some aggravation.
JMHO
Old Jan 11, 2009 | 10:30 AM
SportyPig's Avatar
SportyPig
Yes, I ran into that also. And was getting pretty frustrated with all that. I just got lucky when I found a guy that will mount and balance the tire for $15. He's only 10 minutes from me. So, I can usually take the wheel off, get the new tire mounted and have the wheel back on in about 90 minutes.
Old Jan 13, 2009 | 07:54 AM
krazedstang
thanks guys, it doesn't sound too bad just all the tools that i dont have, i have tools mainly for working on cars (i went through auto technican schooling) so i have a pretty good idea on how stuff works, i have already changed my ignition module, primary gasket and clutch cable, next over the winter its, brakes, tire, grips and a speed sensor! sounds like i have my work cut out for me. i'll give this tire a shot and if not, i believe i know a guy who has a tire changing station in his garage. thanks a lot guys!
Tony
Old Jan 13, 2009 | 11:04 AM
capttawes's Avatar
capttawes
Hey Tony, I'm sure being mechanically minded and having tools there is little you'll need except for a cheap lift and some tire irons. Another tip I forgot to mention is that when inflating the tire its tough to get the bead to seat but my little pancake compressor still managed to do the trick. If your buddy has a tire changer then your set only most auto tire changers dont typically work with cycle rims unless then have the small rod hold down that will fit through the axle hole.
scuzzy
Wheels/Tires
Aug 26, 2016 09:32 PM
Fatboy Brian
Apr 4, 2010 07:34 AM
cromagnon
Dec 22, 2008 03:10 PM
bigtop1
May 23, 2008 02:32 PM
2tonebob
May 19, 2008 09:00 AM
