Too lean
Old Apr 25, 2006 | 10:02 PM
tim@tmgdesigns's Avatar
tim@tmgdesigns
Default Too lean
I bought a 02 XL that had a set of Samson shorties and a hypercharger on it. I was a little shocked at the lack of power that the bike had, and sometimes it will diesel. I asked an HD mechanic to look at it while it was in for a new tire. I was informed that it was never jetted from stock when the pipes and intake was changed. He recommended that it be done asap. Spark plugs were white. I am a little concerned that potentially some damage could have been done running that lean for who knows how long. Does anyone think that this could be an issue?
Old Apr 25, 2006 | 10:32 PM
Big Cholla's Avatar
Big Cholla
Default RE: Too lean
Tim: YES! It could be a big problem. Have a mechanic pull the plugs and look at the top of the pistons with a flexible optical device. He will be looking for cratering in the piston. The lack of power is not a good sign either. The rings in one piston may have already broken from the detonation occurring at higher speeds. Do what you can now. If your bike is a XL 883, this might be a good time to go to the 1200 cc conversion. You will cure all the above problems. ............ BC
Old Apr 26, 2006 | 02:28 AM
Blackbird's Avatar
Blackbird
Running lean can burn the exhaust valve and cause loss of compression/power. You should have your compression checked. If it's low you probably have burned exhaust valves.
Old Apr 26, 2006 | 03:22 AM
skullcrusher's Avatar
skullcrusher
Haveing it checked wont hurt at all! I have a 05 sporty and changes my pipes today with 1100 miles on it, and m stock pipes already were blueing.
Old May 1, 2006 | 10:27 AM
tim@tmgdesigns
Thanks for all the help. Motor was ok. I installed a Dynojet kit yesterday and that seemed to stop the coughing and wake it up.
tbroder55
Welcome Area Only
Jul 23, 2013 03:16 PM
Cyclenby
Engine Mechanical Topics
Jul 9, 2013 06:12 PM
Quickie
Oct 5, 2007 05:40 AM
LarryJ00
Jul 24, 2007 01:22 AM
bfrog1507
May 22, 2006 09:52 PM
